bullfrog1
Jul 10, 2013Tutor
How Bricked is this unit - SOLVED - bad memory
Hi I own 5 readynas NV+'s purchased from new, we also have 2100's,NVX's at work. I've taken a risk and purchased a second user 2100. When power is applied the USB and disk 2 lights come on solid an...
adirtymonkey
Jul 31, 2013Aspirant
Have reseated a couple of times but that didn't do the trick.
Found a 1Gb stick of CL5 5300 DDR2 in a laptop, swapped that over and up and running again. The quest now continues for a definitive answer to memory specs for the V2 2100's.
