bullfrog1
Jul 10, 2013Tutor
How Bricked is this unit - SOLVED - bad memory
Hi I own 5 readynas NV+'s purchased from new, we also have 2100's,NVX's at work. I've taken a risk and purchased a second user 2100. When power is applied the USB and disk 2 lights come on solid an...
django1
Jan 14, 2014Aspirant
StephenB wrote: What NAS model do you have?
django wrote: Hi All,
I have come across the same problem with my machine. I have tried to test it by using a 512mb CL5 PC2-5300 DDR2 SO DIMM chip and it is giving me the same response.
Does the chip need to be a minimum of 1GB or does it need to be ECC?
Not sure if the unit is entirely bricked.
I have the same as the others a ReadyNas 2100. Tried to ring up support all they can say it that it is faulty and needs to be changed, but I think mine might be out of warranty
