rcperkinsjr
Feb 12, 2024Follower
How can I setup ReadyNas now that ReadyCloud is gone?
The instructions to install and setup my ReadyNAS says to go to ReadyCloud, log in and have it search my network for the device. With it being gone, what is the method to set it up with now? Than...
Feb 12, 2024Guru - Experienced User
You just browse to https://nas-ip-address/admin (where nas-ip-address is a placeholder for the real NAS IP address).
If your NAS has an LCD panel, you can see that IP address on the panel. Other options are to check your router's attached device list, or use RAIDar.
The default admin password is netgear1 for ReadyNAS running 4.x firmware, and it is password for ReadyNAS running 5.3.x or 6.x firmware.
