advocate1
Apr 10, 2014Guide
How do I get presale questions answered?
I spent about an hour and a half calling Netgear today to try to get some basic presale questions answered about the difference between the RN314xx and RN104xx, but I just got a bunch of people who tr...
mdgm-ntgr
Apr 10, 2014NETGEAR Employee Retired
The 314 is much better than the 104.
The 314 has an Intel Atom CPU and 2GB RAM, and a HDMI port for possible future use.
The 104 has an ARM CPU, and 512MB RAM (which is soldered on).
The 314 has much better performance, is compatible with a larger range of apps and will cope better if you want to do a lot with it.
I would recommend the 314 over the 104.
