a4rover's avatar
a4rover
Follower
Apr 18, 2020
How do I reset username and password no data is stored firmware is 6.02
f
  • JohnCM_S's avatar
    Apr 18, 2020
    Hi a4rover,
    You can do an OS re-install to reset the admin password back to default settings. You may check this article for the steps on how to access the boot menu and select OS re-install.
    Note: The default admin credential of the RN424 is admin for the username and password for the password.
ProSupport for Business
