a4rover
Apr 18, 2020Follower
How do I reset username and password no data is stored firmware is 6.02
f
- Apr 18, 2020
Hi a4rover,
You can do an OS re-install to reset the admin password back to default settings. You may check this article for the steps on how to access the boot menu and select OS re-install.
Note: The default admin credential of the RN424 is admin for the username and password for the password.
JohnCM_S
Apr 21, 2020NETGEAR Employee Retired
Hi a4rover,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as a solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
