Zipster
Oct 30, 2016Follower
How do you setup the RadyNas 314 with a static IP address?
vandermerwe
Oct 30, 2016Master
Login to the GUI, navigate to the Network tab.
There you will see the network adapter, click on the small Settings cog, select settings, then IP4 and change the settings according to your needs.
DHCP with reserved IP addresses is usually preferable.
