Zipster
Oct 30, 2016Follower
How do you setup the RadyNas 314 with a static IP address?
sotrack
Oct 30, 2016Luminary
IP address for NAS is a router area of responsibility. Correct way is to assign static IP address to NAS on router side. Modern routers are able to assign static IP address based on MAC address from NAS. This IP address should be from dynamic range of router IP addresses. In this case NAS should use dynamic IP configiration based on DHCP and NAS will not be aware - his dynamic address is static.
- StephenBOct 30, 2016Guru - Experienced User
I agree that this is a better approach. Netgear routers call this feature "address reservation".
The benefits include
-it is easier to avoid accidental IP address conflicts
-if you switch routers or change your router's address range, the NAS remains accessible.
Though the NAS will let you set up a static address if you wish.
