wlyan
Jan 04, 2013Aspirant
How long should memory test run on Ultra 4?
I just upgraded the memory of my Ultra 4 to 2GB with Crucial 2GB 200-Pin DDR2 SO-DIMM DDR2 800 (PC2 6400) Laptop Memory Model CT25664AC800. I started the memory test from boot menu. It's been running ...
wlyan
Also, hope my chip's info helps. I bought my 2GB DIMM from Newegg http://www.newegg.com/Product/Product.aspx?Item=N82E16820148162 about two months ago. It has 16 chips, 8 on each side.
