Geohans
Dec 27, 2020Tutor
How to downgrade BIOS 07/26/2010 FLAME6-MB V2.0 back to 10/03/2008 FLAME6-MB V1.6
My Pro Business Edition is not working properly any more after I rolled back a OS6 install to OS4. I suspect it could be caused by the BIOS upgrade to 07/26/2010 FLAME6-MB V2.0 I done before the ...
- Dec 29, 2020
The motherboards of the -100, -200, and even the Ultra6Plus are all identical. The processor they shipped with is different. I'm pretty sure all of the -200 units shipped with the latest BIOS. Most -100's didn't, and that's what I had and updated.
I remember reading in the forum that there was a very early version of the motherboard that shipped in a very limited number of systems. But the BIOS update would recognize that and not do the update.
Dec 30, 2020Guru - Experienced User
Geohans wrote:
My backup options with rsync are not working.
I don't see how the bios would affect that.
Can you give more information on what errors you are seeing (and more details on how the rsync backup jobs are set up)?
Geohans
Dec 30, 2020Tutor
OS6 is now running.....and...stable.
Backup with Rsync-server works also fine.
I thanks for the help.
