Ullas
Feb 01, 2018Aspirant
How to recover data from readynas 31400
Hi,
Please suggest how to recover data from readynas 31400.
unfortunately i have deleted some data by mistake.
model version: ReadyNAS 314
firmware: 6.9.2
- Marc_VNETGEAR Employee Retired
Hi Ulas
Welcome to the community!
You may want to check your Snapshots from the date before you accidentally deleted the files.
Here is an article for that: Rollback a SnapshotThere are other recovery options as well from 3rd party apps that other users might suggest.
hope this helps!
Regards!
- SandsharkSensei
Since Rollback will destroy newer data, you may want to use Browse instead. The instructions above get you to the right point, just chose Browse instead of Rollback. You can select folders or files to restore. Alternately, you can choose "Allow snapshot access" in the share's snapshot setting and browse via an external device.
Hi Ullas
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
