Trench_Rich
Aug 08, 2018Aspirant
how to vertically expand a ReadyNAS 104
I bought a ReadyNAS104 a couple of years ago with one 3TB disk.
Now that that disk is full, I bought another 3TB disk to increase the capacity to 6TB.
I stuck the new hard drive into the box, and...
Trench_Rich
If I remove the second drive and reboot the NAS, is there any way to get it back to a single disk system and start over?
Could I then make the system into a JBOD (or something) array and have it (re)format the second hard drive so I can use it?
Marc_V
Aug 08, 2018NETGEAR Employee Retired
There is no other way than to change to Flex-RAID and destroy the current volume created or do a Factory reset and start with Flex-RAID. The RAID is now RAID 1 so these are the only option :(
Both will be destructive so you need to do a backup.
Regards
- Trench_RichAug 08, 2018Aspirant
So, if I have no choice but to add another hard drive, what options do I have with the drive: does it have to be exactly the same as the original disks (WD Red 3TB), or can it be just the cheapest I can find?
- Marc_VAug 08, 2018NETGEAR Employee Retired
It would be better if you get the same drive as with the first two that you have :)
If you can avoid Desktop drives and go with WD Reds then it will be best.
OR you can disable XRAID add the 3rd drive, set it as JBOD then transfer the files and go DESTROY the other volume and set the other 2 again as JBOD,
But JBOD does not have any data protection, once it failed you don't have any data to be recovered.
Regards
- StephenBAug 08, 2018Guru - Experienced User
If you need to get a different size disk (either bigger or smaller), then this might be a good approach. But if you are getting another 3 TB drive, you are better off sticking with XRAID.
As far as disks go, I have quite a few WD30EFRX deployed, and they've worked out well for me. A Seagate 3 TB IronWolf would also be a good option, so you could price them both. I don't recommend going with desktop drives. NAS-purposed drives like the Red and the IronWolf are much better choices.
- Marc_VAug 13, 2018NETGEAR Employee Retired
Hi Trench_Rich
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,- Trench_RichAug 13, 2018Aspirant
I don't have any money to buy another hard drive at the moment, so this issue will remain unresolved for me until I can get another drive.
- StephenBAug 13, 2018Guru - Experienced User
Which I guess also means that you don't have the ability to back up your NAS (since you could solve it w/o a purchase if you did).
I'd recommend investing in a backup plan before you expand capacity. Although RAID isn't enough to protect your data, it does offer more protection than jbod (which is what you had with only a single drive).
