dandan123
Jun 28, 2015Aspirant
Hybrid HDDs on ReadyNAS Ultra 2
Hi, I would like to know if there is any problem (e.g. wear out faster, performance will degrade fast, as TRIM isn't supported, ...) if I use Hybrid HDD (e.g. SATA3 2.0TB SEAGATE SSHD HYBRID 64M ST...
dandan123
Jul 05, 2015Aspirant
I am not relay looking for performance gain, but more for reliability, since SSHD use less the mechanical (headers). The most used files are hold on the cash side (SSD).
I have also used ST2000DM001 in RAID for a few years without any problem.
Since the price is almost the same (HD vs SSHD) I would like to use SSHD. Actually the question is: can SSHD be worse than HD on ReadyNAS Ultra 2 ?
Thanks
Thanks
