tim_hamblin's avatar
tim_hamblin
Initial findings with new Duo V2
I've already sent a few posts about my initial experience with the new Duo V2, but thought it easier to put it into one feedback post...
I've previously used the ReadyNAS Duo (V1) for a few years, with a final hardware configuration with 1GB RAM and 2x Seagate 2TB HDDs (ST2000DL003)
So, back to the new Duo V2 (running arm 5.3.2), this was the RND2000-200EUS (diskless) model - I'm UK-based, but there doesn't appear to a UK SKU, but the EU model does include a UK and Euro power cables...
Hardware Compatibility List:
This doesn't appear to have the 2TB version of my previous Seagate HDDs, but does have the 1.5TB version, so I initially installed the two ST2000DL003 drives.
I later replaced these with Western Digital (WD20EARX) 2TB HDDs (see below why)...
GUI:
Loads much faster, bit more bling, simpler to navigate, etc...
However, having been used to Front View, it is a bit limited. I can understand this, as it probably targetted to the home-user more than the pro-sumer...
Performance:
Read/writes over the network greatly improved - 40-50MB/s... However, going back to the GUI - you can't adjust the MTU, and currently it is not set up for Jumbo Packets ('ping -f -l' can easily prove that), would this improve performance?
(Works great over wireless too - but didn't benchmark).
DNLA:
I guess still under development - if you modify a file (e.g mp3 ID tag), it will still broadcasts the original version. Going back to the GUI - there is no option to 'Rescan Media'... Hopefully resolved with new firmware.
ReadyNAS Remote:
Doesn't work with iOS devices (iPhone/iPad, etc) as yet. Hopefully resolved with new firmware.
Volume Scan (i_block errors):
Here's my main issue - which might be a problem with my particular Duo V2...
When I did a Restart with Volume Scan, I would get a notification email about 'Volume scan found and corrected errors'. These errors were all related to: Pass 1: Checking inodes, blocks, and sizes - Inode 26181655, i_blocks is 739472, should be 739480. Fix? yes (for about 4-10 different Inode/i_block references). This occured after heavy writes made to the Duo. Once the Volume Scan corrected these errors, subsequent restarts had no errors until a large amount of more data was copied to the Duo.
I initially thought this was due to the Seagte drives not being on the HCL, so went out and purchased two new WD drives (WD20EARX) that were on the HCL... I rebuilt the Duo (volume build takes about 7 hours!). However, as before - started to get the same i_block erros on restart/volume scan... I've just reinstalled the arm 5.3.2 firmware and kicked off a factory reset, so we'll see what happens next...
Summary:
Much improved performance,but still early days in terms of the firmware... Fustration at possible RMA for a brand new (week-old) Duo V2...
Can someone please shed more light on these Inode/i_blocks erros please (below is a last example prior to reinstalling the firmware)...?
***** File system check performed at Sat Jan 7 10:11:28 WET 2012 *****
fsck from util-linux-ng 2.17.2
e2fsck 1.41.14 (22-Dec-2010)
Inode 26181996, i_blocks is 547568, should be 547576. Fix? yes
Inode 26182037, i_blocks is 671744, should be 671752. Fix? yes
Inode 26182083, i_blocks is 594160, should be 594168. Fix? yes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/mapper/c-c: ***** FILE SYSTEM WAS MODIFIED *****
/dev/mapper/c-c: 14538/30285824 files (1.0% non-contiguous), 79676625/484573184 blocks
  • Sounds like a confirmed ID to me. I did PM someone who seems to have a close connection to Tech Support.
  • tim_hamblin wrote:
    I ended up pushing back on the Support... They initially just closed the case for no reason... The Health Status is a bit confusing as all 'LEDs' show Green status. But Volume Scan finds and corrects errors (i_blocks related) after heavy writes made to the Duo V2... This is not just with WD HDDs, as I found this to be an issue with Seagate HDDs...
    My other issue was the disappearing Add-ons... I've done some more testing - this might be related to a corrupt ARM 5.3.2 firmware from ReadyNAS website (which I have downloaded several times)...
    Factory Defaults >> Add-ons available in Dashboard to install and configure
    (Re)install 5.3.2 firmware downloaded from ReadyNAS website >> Add-ons disappear from Dashboard
    Install 5.3.3[T8] beta firmware >> Add-ons available
    Roll-back to 5.3.2 firmware from ReadyNAS website >> Add-ons disppear from Dashboard...
    I was also given then RMA authorization today.
    Tech support had me try and boot to OS reinstall. But I couldn't get past Boot Mode > Normal. They figured the unit was bad and are sending out the RMA.
    I also downloaded the 5.3.2 FW from the site and also lost all my add-ons. i had to delete and reinstall to get them back. it took a power cycle to get it back to "normal." Did the 5.3.3 FW clear up the errors found under a volume scan?
    I feel your pain on not getting the right RMA sent out the first time. I hope I don't have to deal with that also.
  • I had a very productive call and email exchange with NetGear Support in the UK yesterday, and the wheels are now in motion for the correct ReadyNAS Duo V2 replacement (which is being Advance Shipped as we speak)... Thank you!!
    Hopefully the confusion that there has been with this new model has now been clarified, so that future support and RMAs wouldn't need to go through the same teething process...
    The UK NetGear Support number is at +44(0)8448 75 4000, and there is also a new specific Support line for ReadyNAS and ProSafe products: 0843 453 8000
    Alas no, the Voume Scan errors didn't go away with 5.3.3... The Volume Scan corrected the i_blocks errors, but every reboot after writing data to the NAS found more errors...
  • I'd like to reiterate the Volume Scan (i_block errors) problem. Have the same thing here. My ReadyNas Duo v2 is on an UPS, all graceful shutdowns, no weirdness. Also have a problem (sometimes) when copying large (1GB) files to the NAS. "Disk Full". Restart copying and everything is ok. Here's my log for the i_block errors:
    ***** File system check performed at Tue Jan 24 15:50:50 EST 2012 *****
    Inode 17727538, i_blocks is 717976, should be 717984. Fix? yes
    Inode 17727539, i_blocks is 717944, should be 717952. Fix? yes
    Inode 17727540, i_blocks is 717968, should be 717976. Fix? yes
    Inode 17727541, i_blocks is 717912, should be 717920. Fix? yes
    Inode 17727542, i_blocks is 717928, should be 717936. Fix? yes
    Inode 17727543, i_blocks is 717904, should be 717912. Fix? yes
    Inode 17727544, i_blocks is 717944, should be 717952. Fix? yes
    Inode 17727545, i_blocks is 717976, should be 717984. Fix? yes
    Inode 17727546, i_blocks is 717968, should be 717976. Fix? yes
    Inode 17727547, i_blocks is 717984, should be 717992. Fix? yes
    Inode 17727548, i_blocks is 717968, should be 717976. Fix? yes
    Inode 17727549, i_blocks is 717896, should be 717904. Fix? yes
    Inode 17727550, i_blocks is 717960, should be 717968. Fix? yes
    Inode 17727551, i_blocks is 717976, should be 717984. Fix? yes
    Inode 17727552, i_blocks is 717976, should be 717984. Fix? yes
    Inode 17727553, i_blocks is 717904, should be 717912. Fix? yes
    Inode 17727554, i_blocks is 717904, should be 717912. Fix? yes
    Inode 17727555, i_blocks is 717896, should be 717904. Fix? yes
    Inode 17727556, i_blocks is 717912, should be 717920. Fix? yes
    Inode 17727557, i_blocks is 717960, should be 717968. Fix? yes
    Inode 17727558, i_blocks is 717968, should be 717976. Fix? yes
    Inode 17727559, i_blocks is 717912, should be 717920. Fix? yes
    Inode 17956866, i_blocks is 717488, should be 717496. Fix? yes
    Inode 17956867, i_blocks is 717480, should be 717488. Fix? yes
    Inode 17956868, i_blocks is 717560, should be 717568. Fix? yes
    Inode 17956869, i_blocks is 717536, should be 717544. Fix? yes
    Inode 17956870, i_blocks is 717544, should be 717552. Fix? yes
    Inode 17956871, i_blocks is 717120, should be 717128. Fix? yes
    Inode 17956872, i_blocks is 717568, should be 717576. Fix? yes
    Inode 17956873, i_blocks is 717624, should be 717632. Fix? yes
    Inode 17956874, i_blocks is 717280, should be 717288. Fix? yes
    Inode 17956875, i_blocks is 717592, should be 717600. Fix? yes
    Inode 17956876, i_blocks is 717536, should be 717544. Fix? yes
    Inode 17956877, i_blocks is 717528, should be 717536. Fix? yes
    Inode 17956878, i_blocks is 717640, should be 717648. Fix? yes
    Inode 17956879, i_blocks is 717072, should be 717080. Fix? yes
    Inode 17956880, i_blocks is 717640, should be 717648. Fix? yes
    Inode 17956881, i_blocks is 716720, should be 716728. Fix? yes
    Inode 17956882, i_blocks is 716688, should be 716696. Fix? yes
    Inode 17956883, i_blocks is 717464, should be 717472. Fix? yes
    Inode 17956884, i_blocks is 717656, should be 717664. Fix? yes
    Inode 17956885, i_blocks is 717328, should be 717336. Fix? yes
    Inode 17956886, i_blocks is 717184, should be 717192. Fix? yes
    Inode 17956887, i_blocks is 717592, should be 717600. Fix? yes
    Inode 17956888, i_blocks is 717504, should be 717512. Fix? yes
    Inode 17956889, i_blocks is 717464, should be 717472. Fix? yes
    Inode 18087938, i_blocks is 717288, should be 717296. Fix? yes
    Inode 18087939, i_blocks is 717328, should be 717336. Fix? yes
    Inode 18087940, i_blocks is 717608, should be 717616. Fix? yes
    Inode 18087941, i_blocks is 717448, should be 717456. Fix? yes
    Inode 18087942, i_blocks is 717360, should be 717368. Fix? yes
    Inode 18087943, i_blocks is 717112, should be 717120. Fix? yes
    Inode 18087944, i_blocks is 717416, should be 717424. Fix? yes
    Inode 18087945, i_blocks is 717168, should be 717176. Fix? yes
    Inode 18087946, i_blocks is 717608, should be 717616. Fix? yes
    Inode 18087947, i_blocks is 717696, should be 717704. Fix? yes
    Inode 18087948, i_blocks is 717568, should be 717576. Fix? yes
    Inode 18087949, i_blocks is 717488, should be 717496. Fix? yes
    Inode 18087950, i_blocks is 717296, should be 717304. Fix? yes
    Inode 18087951, i_blocks is 717024, should be 717032. Fix? yes
    Inode 18087952, i_blocks is 717176, should be 717184. Fix? yes
    Inode 18087953, i_blocks is 717536, should be 717544. Fix? yes
    Inode 18087954, i_blocks is 717440, should be 717448. Fix? yes
    Inode 18087955, i_blocks is 717472, should be 717480. Fix? yes
    Inode 18087956, i_blocks is 717424, should be 717432. Fix? yes
    Inode 18087957, i_blocks is 717664, should be 717672. Fix? yes
    Inode 18087958, i_blocks is 717616, should be 717624. Fix? yes
    Inode 18087959, i_blocks is 717592, should be 717600. Fix? yes
    Inode 18087960, i_blocks is 717592, should be 717600. Fix? yes
    Inode 18087961, i_blocks is 717616, should be 717624. Fix? yes
    Inode 18087962, i_blocks is 716624, should be 716632. Fix? yes
    Inode 18087963, i_blocks is 717544, should be 717552. Fix? yes
    Inode 18251779, i_blocks is 715136, should be 715144. Fix? yes
    Inode 18251780, i_blocks is 715112, should be 715120. Fix? yes
    Inode 18251781, i_blocks is 715112, should be 715120. Fix? yes
    Inode 18251782, i_blocks is 715120, should be 715128. Fix? yes
    Inode 18251783, i_blocks is 719056, should be 719064. Fix? yes
    Inode 18251784, i_blocks is 715160, should be 715168. Fix? yes
    Inode 18251785, i_blocks is 709984, should be 709992. Fix? yes
    Inode 18251786, i_blocks is 715184, should be 715192. Fix? yes
    Inode 18251787, i_blocks is 710048, should be 710056. Fix? yes
    Inode 18251788, i_blocks is 709904, should be 709912. Fix? yes
    Inode 18251789, i_blocks is 718096, should be 718104. Fix? yes
    Inode 18251790, i_blocks is 718080, should be 718088. Fix? yes
    Inode 18251791, i_blocks is 718088, should be 718096. Fix? yes
    Inode 18251792, i_blocks is 718088, should be 718096. Fix? yes
    Inode 18251793, i_blocks is 715160, should be 715168. Fix? yes
    Inode 18251794, i_blocks is 715136, should be 715144. Fix? yes
    Inode 18251795, i_blocks is 715064, should be 715072. Fix? yes
    Inode 18251796, i_blocks is 715120, should be 715128. Fix? yes
    Inode 18251797, i_blocks is 718080, should be 718088. Fix? yes
    Inode 18251798, i_blocks is 718072, should be 718080. Fix? yes
    Inode 18251799, i_blocks is 718072, should be 718080. Fix? yes
    Inode 18251800, i_blocks is 717992, should be 718000. Fix? yes
    Inode 18251801, i_blocks is 714776, should be 714784. Fix? yes
    Inode 18251802, i_blocks is 715192, should be 715200. Fix? yes
    Inode 18415631, i_blocks is 705168, should be 705176. Fix? yes
    Inode 18415633, i_blocks is 640832, should be 640840. Fix? yes
    Inode 18481214, i_blocks is 716792, should be 716800. Fix? yes
    Inode 18481215, i_blocks is 716792, should be 716800. Fix? yes
    Inode 18481216, i_blocks is 714832, should be 714840. Fix? yes
    Inode 18481217, i_blocks is 716824, should be 716832. Fix? yes
    Inode 18481218, i_blocks is 716816, should be 716824. Fix? yes
    Inode 18481219, i_blocks is 716624, should be 716632. Fix? yes
    Inode 18481220, i_blocks is 716576, should be 716584. Fix? yes
    Inode 18481221, i_blocks is 716816, should be 716824. Fix? yes
    Inode 18481222, i_blocks is 716800, should be 716808. Fix? yes
    Inode 18481223, i_blocks is 716536, should be 716544. Fix? yes
    Inode 18481224, i_blocks is 716792, should be 716800. Fix? yes
    Inode 18481225, i_blocks is 716808, should be 716816. Fix? yes
    Inode 18481226, i_blocks is 716824, should be 716832. Fix? yes
    Inode 18481227, i_blocks is 716848, should be 716856. Fix? yes
    Inode 18481228, i_blocks is 716824, should be 716832. Fix? yes
    Inode 18481229, i_blocks is 716824, should be 716832. Fix? yes
    Inode 18481230, i_blocks is 716824, should be 716832. Fix? yes
    Inode 18481231, i_blocks is 716832, should be 716840. Fix? yes
    Inode 18481232, i_blocks is 716824, should be 716832. Fix? yes
    Inode 18481233, i_blocks is 716792, should be 716800. Fix? yes
    Inode 18481234, i_blocks is 716808, should be 716816. Fix? yes
    Inode 18481235, i_blocks is 716816, should be 716824. Fix? yes
    Inode 18481236, i_blocks is 716808, should be 716816. Fix? yes
    Inode 18481237, i_blocks is 716808, should be 716816. Fix? yes
    Inode 18644994, i_blocks is 716808, should be 716816. Fix? yes
    Inode 18644995, i_blocks is 716816, should be 716824. Fix? yes
    Inode 18644996, i_blocks is 716784, should be 716792. Fix? yes
    Inode 18644997, i_blocks is 716816, should be 716824. Fix? yes
    Inode 18644998, i_blocks is 716792, should be 716800. Fix? yes
    Inode 18644999, i_blocks is 716792, should be 716800. Fix? yes
    Inode 18645000, i_blocks is 716800, should be 716808. Fix? yes
    Inode 18645001, i_blocks is 716816, should be 716824. Fix? yes
    Inode 18645002, i_blocks is 716832, should be 716840. Fix? yes
    Inode 18645003, i_blocks is 716808, should be 716816. Fix? yes
    Inode 18645004, i_blocks is 716824, should be 716832. Fix? yes
    Inode 18645005, i_blocks is 716792, should be 716800. Fix? yes
    Inode 18645006, i_blocks is 716800, should be 716808. Fix? yes
    Inode 18645007, i_blocks is 716824, should be 716832. Fix? yes
    Inode 18645008, i_blocks is 716792, should be 716800. Fix? yes
    Inode 18645009, i_blocks is 716832, should be 716840. Fix? yes
    Inode 18645010, i_blocks is 716824, should be 716832. Fix? yes
    Inode 18645011, i_blocks is 716824, should be 716832. Fix? yes
    Inode 18645012, i_blocks is 716824, should be 716832. Fix? yes
    Inode 18645013, i_blocks is 716840, should be 716848. Fix? yes
    Inode 18645014, i_blocks is 716800, should be 716808. Fix? yes
    Inode 18645015, i_blocks is 716816, should be 716824. Fix? yes
    Inode 18645016, i_blocks is 716808, should be 716816. Fix? yes
    Inode 18645017, i_blocks is 716816, should be 716824. Fix? yes
    Inode 18645018, i_blocks is 716808, should be 716816. Fix? yes
    Inode 18645019, i_blocks is 716816, should be 716824. Fix? yes
    Inode 18808834, i_blocks is 716808, should be 716816. Fix? yes
    Inode 18808835, i_blocks is 716800, should be 716808. Fix? yes
    Inode 18808836, i_blocks is 716816, should be 716824. Fix? yes
    Inode 18808837, i_blocks is 716776, should be 716784. Fix? yes
    Inode 18808838, i_blocks is 716784, should be 716792. Fix? yes
    Inode 18808839, i_blocks is 716808, should be 716816. Fix? yes
    Inode 18808840, i_blocks is 717496, should be 717504. Fix? yes
    Inode 18808841, i_blocks is 716824, should be 716832. Fix? yes
    Inode 18808842, i_blocks is 716808, should be 716816. Fix? yes
    Inode 18808843, i_blocks is 716760, should be 716768. Fix? yes
    Inode 18808844, i_blocks is 716808, should be 716816. Fix? yes
    Inode 18808845, i_blocks is 716792, should be 716800. Fix? yes
    Inode 18808846, i_blocks is 716816, should be 716824. Fix? yes
    Inode 18808847, i_blocks is 716792, should be 716800. Fix? yes
    Inode 18808848, i_blocks is 716832, should be 716840. Fix? yes
    Inode 18808849, i_blocks is 716792, should be 716800. Fix? yes
    Inode 18808850, i_blocks is 716784, should be 716792. Fix? yes
    Inode 18808851, i_blocks is 716744, should be 716752. Fix? yes
    Inode 18808852, i_blocks is 716800, should be 716808. Fix? yes
    Inode 18808853, i_blocks is 716800, should be 716808. Fix? yes
    Inode 18808854, i_blocks is 716776, should be 716784. Fix? yes
    Inode 18808855, i_blocks is 716752, should be 716760. Fix? yes
    Inode 18808856, i_blocks is 716800, should be 716808. Fix? yes
    Inode 18808857, i_blocks is 716776, should be 716784. Fix? yes
    Inode 18808858, i_blocks is 716768, should be 716776. Fix? yes
    Inode 18808859, i_blocks is 716776, should be 716784. Fix? yes
    Inode 18939906, i_blocks is 716808, should be 716816. Fix? yes
    Inode 18939907, i_blocks is 716824, should be 716832. Fix? yes
    Inode 18939908, i_blocks is 716776, should be 716784. Fix? yes
    Inode 18939909, i_blocks is 716784, should be 716792. Fix? yes
    Inode 18939910, i_blocks is 716792, should be 716800. Fix? yes
    Inode 18939911, i_blocks is 716832, should be 716840. Fix? yes
    Inode 18939912, i_blocks is 716800, should be 716808. Fix? yes
    Inode 18939913, i_blocks is 716808, should be 716816. Fix? yes
    Inode 18939914, i_blocks is 716800, should be 716808. Fix? yes
    Inode 18939915, i_blocks is 716656, should be 716664. Fix? yes
    Inode 18939916, i_blocks is 716776, should be 716784. Fix? yes
    Inode 18939917, i_blocks is 716776, should be 716784. Fix? yes
    Inode 18939918, i_blocks is 716768, should be 716776. Fix? yes
    Inode 18939919, i_blocks is 716776, should be 716784. Fix? yes
    Inode 18939920, i_blocks is 716784, should be 716792. Fix? yes
    Inode 18939921, i_blocks is 716768, should be 716776. Fix? yes
    Inode 18939922, i_blocks is 716792, should be 716800. Fix? yes
    Inode 18939923, i_blocks is 716816, should be 716824. Fix? yes
    Inode 18939924, i_blocks is 716808, should be 716816. Fix? yes
    Inode 18939925, i_blocks is 716808, should be 716816. Fix? yes
    Inode 18939926, i_blocks is 716792, should be 716800. Fix? yes
    Inode 18939927, i_blocks is 716808, should be 716816. Fix? yes
    Inode 18939928, i_blocks is 716776, should be 716784. Fix? yes
    Inode 18939929, i_blocks is 716832, should be 716840. Fix? yes
    Inode 18939930, i_blocks is 716800, should be 716808. Fix? yes
    Inode 18939931, i_blocks is 716808, should be 716816. Fix? yes
    Inode 19103746, i_blocks is 716784, should be 716792. Fix? yes
    Inode 19103747, i_blocks is 716768, should be 716776. Fix? yes
    Inode 19103748, i_blocks is 716760, should be 716768. Fix? yes
    Inode 19103749, i_blocks is 716800, should be 716808. Fix? yes
    Inode 19103750, i_blocks is 716792, should be 716800. Fix? yes
    Inode 19103751, i_blocks is 716792, should be 716800. Fix? yes
    Inode 19103752, i_blocks is 716768, should be 716776. Fix? yes
    Inode 19103753, i_blocks is 716784, should be 716792. Fix? yes
    Inode 19103754, i_blocks is 716816, should be 716824. Fix? yes
    Inode 19103755, i_blocks is 716808, should be 716816. Fix? yes
    Inode 19103756, i_blocks is 716824, should be 716832. Fix? yes
    Inode 19103757, i_blocks is 716792, should be 716800. Fix? yes
    Inode 19103758, i_blocks is 716808, should be 716816. Fix? yes
    Inode 19103759, i_blocks is 716776, should be 716784. Fix? yes
    Inode 19103760, i_blocks is 716752, should be 716760. Fix? yes
    Inode 19103761, i_blocks is 716800, should be 716808. Fix? yes
    Inode 19103762, i_blocks is 716792, should be 716800. Fix? yes
    Inode 19103763, i_blocks is 716784, should be 716792. Fix? yes
    Inode 19103764, i_blocks is 716784, should be 716792. Fix? yes
    Inode 19103765, i_blocks is 716792, should be 716800. Fix? yes
    Inode 19103766, i_blocks is 716760, should be 716768. Fix? yes
    Inode 19103767, i_blocks is 716784, should be 716792. Fix? yes
    Inode 19103768, i_blocks is 716736, should be 716744. Fix? yes
    Inode 19103769, i_blocks is 716816, should be 716824. Fix? yes
    Inode 19103770, i_blocks is 716784, should be 716792. Fix? yes
    Inode 19103771, i_blocks is 716816, should be 716824. Fix? yes
    Inode 19267586, i_blocks is 716800, should be 716808. Fix? yes
    Inode 19267587, i_blocks is 716768, should be 716776. Fix? yes
    Inode 19267588, i_blocks is 716784, should be 716792. Fix? yes
    Inode 19267589, i_blocks is 716784, should be 716792. Fix? yes
    Inode 19267590, i_blocks is 716784, should be 716792. Fix? yes
    Inode 19267591, i_blocks is 716776, should be 716784. Fix? yes
    Inode 19267592, i_blocks is 716768, should be 716776. Fix? yes
    Inode 19267593, i_blocks is 716752, should be 716760. Fix? yes
    Inode 19267594, i_blocks is 716776, should be 716784. Fix? yes
    Inode 19267595, i_blocks is 716792, should be 716800. Fix? yes
    Inode 19267596, i_blocks is 716760, should be 716768. Fix? yes
    Inode 19267597, i_blocks is 716792, should be 716800. Fix? yes
    Inode 19267598, i_blocks is 716800, should be 716808. Fix? yes
    Inode 19267599, i_blocks is 716776, should be 716784. Fix? yes
    Inode 19267600, i_blocks is 716736, should be 716744. Fix? yes
    Inode 19267601, i_blocks is 716800, should be 716808. Fix? yes
    Inode 19267602, i_blocks is 716800, should be 716808. Fix? yes
    Inode 19267603, i_blocks is 716800, should be 716808. Fix? yes
    Inode 19267604, i_blocks is 716776, should be 716784. Fix? yes
    Inode 19267605, i_blocks is 716784, should be 716792. Fix? yes
    Inode 19267606, i_blocks is 716824, should be 716832. Fix? yes
    Inode 19267607, i_blocks is 716752, should be 716760. Fix? yes
    Inode 19398659, i_blocks is 716808, should be 716816. Fix? yes
    Inode 19398660, i_blocks is 716792, should be 716800. Fix? yes
    Inode 19398661, i_blocks is 716808, should be 716816. Fix? yes
    Inode 19398662, i_blocks is 716800, should be 716808. Fix? yes
    Inode 19398663, i_blocks is 716800, should be 716808. Fix? yes
    Inode 19398664, i_blocks is 716800, should be 716808. Fix? yes
    Inode 19398665, i_blocks is 716800, should be 716808. Fix? yes
    Inode 19398666, i_blocks is 716800, should be 716808. Fix? yes
    Inode 19398667, i_blocks is 716792, should be 716800. Fix? yes
    Inode 19398668, i_blocks is 716784, should be 716792. Fix? yes
    Inode 19398669, i_blocks is 716776, should be 716784. Fix? yes
    Inode 19398670, i_blocks is 716800, should be 716808. Fix? yes
    Inode 19398671, i_blocks is 716768, should be 716776. Fix? yes
    Inode 19398672, i_blocks is 716808, should be 716816. Fix? yes
    Inode 19398673, i_blocks is 716776, should be 716784. Fix? yes
    Inode 19398674, i_blocks is 716792, should be 716800. Fix? yes
    Inode 19398675, i_blocks is 716648, should be 716656. Fix? yes
    Inode 19398676, i_blocks is 716360, should be 716368. Fix? yes
    Inode 19398677, i_blocks is 716032, should be 716040. Fix? yes
    Inode 19398678, i_blocks is 716728, should be 716736. Fix? yes
    Inode 19398679, i_blocks is 716752, should be 716760. Fix? yes
    Inode 19398680, i_blocks is 716168, should be 716176. Fix? yes
    Inode 19398681, i_blocks is 716760, should be 716768. Fix? yes
    Inode 19398682, i_blocks is 716760, should be 716768. Fix? yes
    Inode 19628042, i_blocks is 707568, should be 707576. Fix? yes
    Inode 19628043, i_blocks is 707816, should be 707824. Fix? yes
    Inode 19628044, i_blocks is 689720, should be 689728. Fix? yes
    Inode 19628045, i_blocks is 712488, should be 712496. Fix? yes
    Inode 19628046, i_blocks is 707512, should be 707520. Fix? yes
    Inode 19628047, i_blocks is 707688, should be 707696. Fix? yes
    Inode 19628048, i_blocks is 707448, should be 707456. Fix? yes
    Inode 19628049, i_blocks is 707472, should be 707480. Fix? yes
    Inode 19628050, i_blocks is 709312, should be 709320. Fix? yes
    Inode 19628051, i_blocks is 708760, should be 708768. Fix? yes
    Inode 19628052, i_blocks is 679152, should be 679160. Fix? yes
    Inode 19628053, i_blocks is 702432, should be 702440. Fix? yes
    Inode 19628054, i_blocks is 707704, should be 707712. Fix? yes
    Inode 19628055, i_blocks is 698648, should be 698656. Fix? yes
    Inode 19628056, i_blocks is 708512, should be 708520. Fix? yes
    Inode 19628057, i_blocks is 709000, should be 709008. Fix? yes
    Inode 19628058, i_blocks is 707720, should be 707728. Fix? yes
    Inode 19628059, i_blocks is 707512, should be 707520. Fix? yes
    Inode 19628060, i_blocks is 707656, should be 707664. Fix? yes
    Inode 19628061, i_blocks is 707744, should be 707752. Fix? yes
    Inode 19628062, i_blocks is 702864, should be 702872. Fix? yes
    Inode 19628063, i_blocks is 707824, should be 707832. Fix? yes
    Inode 19628064, i_blocks is 707768, should be 707776. Fix? yes
    Inode 19628065, i_blocks is 707808, should be 707816. Fix? yes
    Inode 19791989, i_blocks is 716600, should be 716608. Fix? yes
    Inode 19791990, i_blocks is 717376, should be 717384. Fix? yes
    Inode 19791991, i_blocks is 716304, should be 716312. Fix? yes
    Inode 19791992, i_blocks is 716176, should be 716184. Fix? yes
    Inode 19791993, i_blocks is 716272, should be 716280. Fix? yes
    Inode 19791994, i_blocks is 718504, should be 718512. Fix? yes
    Inode 19791995, i_blocks is 718136, should be 718144. Fix? yes
    Inode 19791996, i_blocks is 716632, should be 716640. Fix? yes
    Inode 19791997, i_blocks is 717768, should be 717776. Fix? yes
    Inode 19791998, i_blocks is 716616, should be 716624. Fix? yes
    Inode 19791999, i_blocks is 716992, should be 717000. Fix? yes
    Inode 19792000, i_blocks is 718456, should be 718464. Fix? yes
    Inode 19792001, i_blocks is 718680, should be 718688. Fix? yes
    Inode 19792002, i_blocks is 717440, should be 717448. Fix? yes
    Inode 19792003, i_blocks is 718240, should be 718248. Fix? yes
    Inode 19792004, i_blocks is 716472, should be 716480. Fix? yes
    Inode 19792005, i_blocks is 718168, should be 718176. Fix? yes
    Inode 19792006, i_blocks is 718080, should be 718088. Fix? yes
    Inode 19792008, i_blocks is 717640, should be 717648. Fix? yes
    Inode 19792009, i_blocks is 718016, should be 718024. Fix? yes
    Inode 19792010, i_blocks is 717816, should be 717824. Fix? yes
    Inode 19792011, i_blocks is 718032, should be 718040. Fix? yes
    Inode 19792012, i_blocks is 717856, should be 717864. Fix? yes
    Inode 19792013, i_blocks is 717656, should be 717664. Fix? yes
    Inode 19792014, i_blocks is 717336, should be 717344. Fix? yes
    Inode 19792015, i_blocks is 717256, should be 717264. Fix? yes
    Inode 19792016, i_blocks is 717656, should be 717664. Fix? yes
    Inode 19792017, i_blocks is 717248, should be 717256. Fix? yes
    Inode 19792018, i_blocks is 717440, should be 717448. Fix? yes
    Inode 19792019, i_blocks is 717664, should be 717672. Fix? yes
    Inode 19792020, i_blocks is 717656, should be 717664. Fix? yes
    Inode 19792021, i_blocks is 717656, should be 717664. Fix? yes
    Inode 19792022, i_blocks is 717640, should be 717648. Fix? yes
    Inode 19792023, i_blocks is 717656, should be 717664. Fix? yes
    Inode 19792024, i_blocks is 717648, should be 717656. Fix? yes
    Inode 19792025, i_blocks is 717640, should be 717648. Fix? yes
    Inode 19792026, i_blocks is 717160, should be 717168. Fix? yes
    Inode 19792027, i_blocks is 717656, should be 717664. Fix? yes
    Inode 19792028, i_blocks is 717664, should be 717672. Fix? yes
    Inode 19792029, i_blocks is 717656, should be 717664. Fix? yes
    Inode 19792030, i_blocks is 717648, should be 717656. Fix? yes
    Inode 19792031, i_blocks is 717656, should be 717664. Fix? yes
    Inode 19792032, i_blocks is 717656, should be 717664. Fix? yes
    Inode 19792033, i_blocks is 717640, should be 717648. Fix? yes
    Inode 19792035, i_blocks is 718032, should be 718040. Fix? yes
    Inode 19792036, i_blocks is 717240, should be 717248. Fix? yes
    Inode 19792037, i_blocks is 717816, should be 717824. Fix? yes
    Inode 19792038, i_blocks is 717432, should be 717440. Fix? yes
    Inode 19792039, i_blocks is 717656, should be 717664. Fix? yes
    Inode 19792040, i_blocks is 717456, should be 717464. Fix? yes
    Inode 19792041, i_blocks is 717656, should be 717664. Fix? yes
    Inode 19792042, i_blocks is 717760, should be 717768. Fix? yes
    Inode 19792043, i_blocks is 717248, should be 717256. Fix? yes
    Inode 19792044, i_blocks is 717872, should be 717880. Fix? yes
    Inode 19792045, i_blocks is 717664, should be 717672. Fix? yes
    Inode 19792046, i_blocks is 717456, should be 717464. Fix? yes
    Inode 19792047, i_blocks is 718232, should be 718240. Fix? yes
    Inode 19792048, i_blocks is 717640, should be 717648. Fix? yes
    Inode 19792049, i_blocks is 717840, should be 717848. Fix? yes
    Inode 19792050, i_blocks is 717648, should be 717656. Fix? yes
    Inode 19792051, i_blocks is 717240, should be 717248. Fix? yes
    Inode 19792052, i_blocks is 718056, should be 718064. Fix? yes
    Inode 19792053, i_blocks is 717648, should be 717656. Fix? yes
    Inode 19792054, i_blocks is 717232, should be 717240. Fix? yes
    Inode 19792055, i_blocks is 717056, should be 717064. Fix? yes
    Inode 19792056, i_blocks is 717648, should be 717656. Fix? yes
    Inode 19792057, i_blocks is 717248, should be 717256. Fix? yes
    Inode 19792058, i_blocks is 717632, should be 717640. Fix? yes
    Inode 19792059, i_blocks is 718056, should be 718064. Fix? yes
    Inode 19792060, i_blocks is 717648, should be 717656. Fix? yes
    Inode 19792063, i_blocks is 717608, should be 717616. Fix? yes
    Inode 19792064, i_blocks is 717240, should be 717248. Fix? yes
    Inode 19792065, i_blocks is 717616, should be 717624. Fix? yes
    Inode 19792066, i_blocks is 717640, should be 717648. Fix? yes
    Inode 19792067, i_blocks is 717632, should be 717640. Fix? yes
    Inode 19792068, i_blocks is 718624, should be 718632. Fix? yes
    Inode 19792069, i_blocks is 717280, should be 717288. Fix? yes
    Inode 19792070, i_blocks is 719216, should be 719224. Fix? yes
    Inode 19792071, i_blocks is 719408, should be 719416. Fix? yes
    Inode 19792072, i_blocks is 718832, should be 718840. Fix? yes
    Inode 19792073, i_blocks is 717240, should be 717248. Fix? yes
    Inode 19792074, i_blocks is 717432, should be 717440. Fix? yes
    Inode 19792075, i_blocks is 717240, should be 717248. Fix? yes
    Inode 19792076, i_blocks is 719024, should be 719032. Fix? yes
    Inode 19792077, i_blocks is 711104, should be 711112. Fix? yes
    Inode 19792078, i_blocks is 715304, should be 715312. Fix? yes
    Inode 19792079, i_blocks is 718040, should be 718048. Fix? yes
    Inode 19792080, i_blocks is 717240, should be 717248. Fix? yes
    Inode 19792081, i_blocks is 713440, should be 713448. Fix? yes
    Inode 19792082, i_blocks is 717816, should be 717824. Fix? yes
    Inode 19792083, i_blocks is 716976, should be 716984. Fix? yes
    Inode 19792084, i_blocks is 715360, should be 715368. Fix? yes
    Inode 19792085, i_blocks is 719016, should be 719024. Fix? yes
    Inode 19792086, i_blocks is 718632, should be 718640. Fix? yes
    Inode 19792088, i_blocks is 716872, should be 716880. Fix? yes
    Inode 19792089, i_blocks is 717576, should be 717584. Fix? yes
    Inode 19792090, i_blocks is 709800, should be 709808. Fix? yes
    Inode 19792091, i_blocks is 707760, should be 707768. Fix? yes
    Inode 19792092, i_blocks is 709840, should be 709848. Fix? yes
    Inode 19792093, i_blocks is 710104, should be 710112. Fix? yes
    Inode 19792094, i_blocks is 710008, should be 710016. Fix? yes
    Inode 19792095, i_blocks is 717048, should be 717056. Fix? yes
    Inode 19792096, i_blocks is 707536, should be 707544. Fix? yes
    Inode 19792097, i_blocks is 707520, should be 707528. Fix? yes
    Inode 19792098, i_blocks is 706872, should be 706880. Fix? yes
    Inode 19792099, i_blocks is 707704, should be 707712. Fix? yes
    Inode 19792100, i_blocks is 711432, should be 711440. Fix? yes
    Inode 19792101, i_blocks is 711344, should be 711352. Fix? yes
    Inode 19792102, i_blocks is 711360, should be 711368. Fix? yes
    Inode 19792103, i_blocks is 710224, should be 710232. Fix? yes
    Inode 19792104, i_blocks is 716840, should be 716848. Fix? yes
    Inode 19792105, i_blocks is 711928, should be 711936. Fix? yes
    Inode 19792106, i_blocks is 676584, should be 676592. Fix? yes
    Inode 19792107, i_blocks is 709976, should be 709984. Fix? yes
    Inode 19792108, i_blocks is 647272, should be 647280. Fix? yes
    Inode 19792109, i_blocks is 711864, should be 711872. Fix? yes
    Inode 19792110, i_blocks is 709224, should be 709232. Fix? yes
    Inode 19792111, i_blocks is 710032, should be 710040. Fix? yes
    Inode 19792112, i_blocks is 707472, should be 707480. Fix? yes
    Inode 19792113, i_blocks is 708008, should be 708016. Fix? yes
    Inode 19792115, i_blocks is 717000, should be 717008. Fix? yes
    Inode 19792116, i_blocks is 716968, should be 716976. Fix? yes
    Inode 19792117, i_blocks is 717016, should be 717024. Fix? yes
    Inode 19792118, i_blocks is 717024, should be 717032. Fix? yes
    Inode 19792119, i_blocks is 716968, should be 716976. Fix? yes
    Inode 19792120, i_blocks is 716968, should be 716976. Fix? yes
    Inode 19792121, i_blocks is 716960, should be 716968. Fix? yes
    Inode 19792122, i_blocks is 717000, should be 717008. Fix? yes
    Inode 19792123, i_blocks is 717008, should be 717016. Fix? yes
    Inode 19792124, i_blocks is 716968, should be 716976. Fix? yes
    Inode 19792125, i_blocks is 717000, should be 717008. Fix? yes
    Inode 19792126, i_blocks is 717008, should be 717016. Fix? yes
    Inode 19792127, i_blocks is 716992, should be 717000. Fix? yes
    Inode 19792128, i_blocks is 716936, should be 716944. Fix? yes
    Inode 19792129, i_blocks is 717000, should be 717008. Fix? yes
    Inode 19792130, i_blocks is 717000, should be 717008. Fix? yes
    Inode 19792131, i_blocks is 716944, should be 716952. Fix? yes
    Inode 19792132, i_blocks is 716976, should be 716984. Fix? yes
    Inode 19792133, i_blocks is 717000, should be 717008. Fix? yes
    Inode 19792134, i_blocks is 716992, should be 717000. Fix? yes
    Inode 19792135, i_blocks is 717000, should be 717008. Fix? yes
    Inode 19792136, i_blocks is 716968, should be 716976. Fix? yes
    Inode 19792137, i_blocks is 716992, should be 717000. Fix? yes
    Inode 19792138, i_blocks is 716992, should be 717000. Fix? yes
    Inode 19792139, i_blocks is 716984, should be 716992. Fix? yes
    Inode 19792140, i_blocks is 717000, should be 717008. Fix? yes
    Inode 19792147, i_blocks is 775408, should be 775416. Fix? yes
    Inode 19792149, i_blocks is 715640, should be 715648. Fix? yes
    Inode 19792150, i_blocks is 715968, should be 715976. Fix? yes
    Inode 19792151, i_blocks is 715680, should be 715688. Fix? yes
    Inode 19792152, i_blocks is 715656, should be 715664. Fix? yes
    Inode 19792153, i_blocks is 716408, should be 716416. Fix? yes
    Inode 19792154, i_blocks is 716168, should be 716176. Fix? yes
    Inode 19792155, i_blocks is 715832, should be 715840. Fix? yes
    Inode 19792156, i_blocks is 715896, should be 715904. Fix? yes
    Inode 19792157, i_blocks is 715992, should be 716000. Fix? yes
    Inode 19792158, i_blocks is 716768, should be 716776. Fix? yes
    Inode 19792159, i_blocks is 712528, should be 712536. Fix? yes
    Inode 19792160, i_blocks is 714968, should be 714976. Fix? yes
    Inode 19792163, i_blocks is 712208, should be 712216. Fix? yes
    Inode 19792164, i_blocks is 715416, should be 715424. Fix? yes
    Inode 19792165, i_blocks is 715912, should be 715920. Fix? yes
    Inode 19792166, i_blocks is 715224, should be 715232. Fix? yes
    Inode 19792167, i_blocks is 715784, should be 715792. Fix? yes
    Inode 19792168, i_blocks is 717968, should be 717976. Fix? yes
    Inode 19792169, i_blocks is 717224, should be 717232. Fix? yes
    Inode 19792170, i_blocks is 717416, should be 717424. Fix? yes
    Inode 19792171, i_blocks is 716808, should be 716816. Fix? yes
    Inode 19792172, i_blocks is 716128, should be 716136. Fix? yes
    Inode 19792173, i_blocks is 715816, should be 715824. Fix? yes
    Inode 19792174, i_blocks is 716104, should be 716112. Fix? yes
    Inode 19792175, i_blocks is 715144, should be 715152. Fix? yes
    Inode 19792178, i_blocks is 716584, should be 716592. Fix? yes
    Inode 19792179, i_blocks is 716208, should be 716216. Fix? yes
    Inode 19792180, i_blocks is 716000, should be 716008. Fix? yes
    Inode 19792181, i_blocks is 717112, should be 717120. Fix? yes
    Inode 19792182, i_blocks is 715848, should be 715856. Fix? yes
    Inode 19792183, i_blocks is 717448, should be 717456. Fix? yes
    Inode 19792184, i_blocks is 715560, should be 715568. Fix? yes
    Inode 19792185, i_blocks is 715616, should be 715624. Fix? yes
    Inode 19792186, i_blocks is 715904, should be 715912. Fix? yes
    Inode 19792187, i_blocks is 716208, should be 716216. Fix? yes
    Inode 19792188, i_blocks is 715360, should be 715368. Fix? yes
    Inode 19792189, i_blocks is 715816, should be 715824. Fix? yes
    Inode 19792190, i_blocks is 716024, should be 716032. Fix? yes
    Inode 19792192, i_blocks is 716944, should be 716952. Fix? yes
    Inode 19792193, i_blocks is 717984, should be 717992. Fix? yes
    Inode 19792194, i_blocks is 720240, should be 720248. Fix? yes
    Inode 19792195, i_blocks is 717448, should be 717456. Fix? yes
    Inode 19792196, i_blocks is 717168, should be 717176. Fix? yes
    Inode 19792197, i_blocks is 718808, should be 718816. Fix? yes
    Inode 19792198, i_blocks is 717120, should be 717128. Fix? yes
    Inode 19792199, i_blocks is 716832, should be 716840. Fix? yes
    Inode 19792200, i_blocks is 713776, should be 713784. Fix? yes
    Inode 19792201, i_blocks is 718624, should be 718632. Fix? yes
    Inode 19792202, i_blocks is 716728, should be 716736. Fix? yes
    Inode 19792203, i_blocks is 716720, should be 716728. Fix? yes
    Inode 19792204, i_blocks is 716936, should be 716944. Fix? yes
    Inode 19792208, i_blocks is 717560, should be 717568. Fix? yes
    Inode 19792209, i_blocks is 717632, should be 717640. Fix? yes
    Inode 19792210, i_blocks is 717704, should be 717712. Fix? yes
    Inode 19792211, i_blocks is 712000, should be 712008. Fix? yes
    Inode 19792212, i_blocks is 717784, should be 717792. Fix? yes
    Inode 19792213, i_blocks is 711816, should be 711824. Fix? yes
    Inode 19792214, i_blocks is 717304, should be 717312. Fix? yes
    Inode 19792215, i_blocks is 717704, should be 717712. Fix? yes
    Inode 19792216, i_blocks is 717048, should be 717056. Fix? yes
    Inode 19792217, i_blocks is 714256, should be 714264. Fix? yes
    Inode 19792218, i_blocks is 712352, should be 712360. Fix? yes
    Inode 19792228, i_blocks is 717144, should be 717152. Fix? yes
    Inode 19792229, i_blocks is 717080, should be 717088. Fix? yes
    Inode 19792230, i_blocks is 717104, should be 717112. Fix? yes
    Inode 19792231, i_blocks is 717128, should be 717136. Fix? yes
    Inode 19792232, i_blocks is 717144, should be 717152. Fix? yes
    Inode 19792233, i_blocks is 717168, should be 717176. Fix? yes
    Inode 19792234, i_blocks is 717136, should be 717144. Fix? yes
    Inode 19792235, i_blocks is 717136, should be 717144. Fix? yes
    Inode 19792237, i_blocks is 717152, should be 717160. Fix? yes
    Inode 19792238, i_blocks is 715368, should be 715376. Fix? yes
    Inode 19792239, i_blocks is 717128, should be 717136. Fix? yes
    Inode 19792240, i_blocks is 717144, should be 717152. Fix? yes
    Inode 19792241, i_blocks is 716920, should be 716928. Fix? yes
    Inode 19792242, i_blocks is 717112, should be 717120. Fix? yes
    Inode 19792243, i_blocks is 715136, should be 715144. Fix? yes
    Inode 19792244, i_blocks is 717128, should be 717136. Fix? yes
    Inode 19792245, i_blocks is 717120, should be 717128. Fix? yes
    Inode 19792246, i_blocks is 717144, should be 717152. Fix? yes
    Inode 19792247, i_blocks is 717120, should be 717128. Fix? yes
    Inode 19792248, i_blocks is 717080, should be 717088. Fix? yes
    Inode 19792249, i_blocks is 717144, should be 717152. Fix? yes
    Inode 19792250, i_blocks is 717144, should be 717152. Fix? yes
    Inode 19792278, i_blocks is 717064, should be 717072. Fix? yes
    Inode 19792279, i_blocks is 717120, should be 717128. Fix? yes
    Inode 19792280, i_blocks is 717160, should be 717168. Fix? yes
    Inode 19792281, i_blocks is 717168, should be 717176. Fix? yes
    Inode 19792282, i_blocks is 717168, should be 717176. Fix? yes
    Inode 19792283, i_blocks is 717160, should be 717168. Fix? yes
    Inode 19792284, i_blocks is 717112, should be 717120. Fix? yes
    Inode 19792285, i_blocks is 717088, should be 717096. Fix? yes
    Inode 19792286, i_blocks is 717120, should be 717128. Fix? yes
    Inode 19792287, i_blocks is 717112, should be 717120. Fix? yes
    Inode 19792288, i_blocks is 717168, should be 717176. Fix? yes
    Inode 19792289, i_blocks is 717112, should be 717120. Fix? yes
    Inode 19792290, i_blocks is 717112, should be 717120. Fix? yes
    Inode 19792291, i_blocks is 717168, should be 717176. Fix? yes
    Inode 19792292, i_blocks is 717040, should be 717048. Fix? yes
    Inode 19792293, i_blocks is 717152, should be 717160. Fix? yes
    Inode 19792294, i_blocks is 717176, should be 717184. Fix? yes
    Inode 19792295, i_blocks is 717136, should be 717144. Fix? yes
    Inode 19792296, i_blocks is 717128, should be 717136. Fix? yes
    Inode 19792297, i_blocks is 717152, should be 717160. Fix? yes
    Inode 19792298, i_blocks is 717120, should be 717128. Fix? yes
    Inode 19792299, i_blocks is 717104, should be 717112. Fix? yes
    Inode 19792300, i_blocks is 717160, should be 717168. Fix? yes
    Inode 19792301, i_blocks is 717120, should be 717128. Fix? yes
    Inode 19792302, i_blocks is 717136, should be 717144. Fix? yes
    Inode 19792303, i_blocks is 717160, should be 717168. Fix? yes
    Inode 19792332, i_blocks is 717056, should be 717064. Fix? yes
    Inode 19792333, i_blocks is 717040, should be 717048. Fix? yes
    Inode 19792334, i_blocks is 717120, should be 717128. Fix? yes
    Inode 19792335, i_blocks is 717168, should be 717176. Fix? yes
    Inode 19792336, i_blocks is 717200, should be 717208. Fix? yes
    Inode 19792337, i_blocks is 717168, should be 717176. Fix? yes
    Inode 19792338, i_blocks is 717192, should be 717200. Fix? yes
    Inode 19792339, i_blocks is 717208, should be 717216. Fix? yes
    Inode 19792340, i_blocks is 717112, should be 717120. Fix? yes
    Inode 19792341, i_blocks is 717136, should be 717144. Fix? yes
    Inode 19792342, i_blocks is 717168, should be 717176. Fix? yes
    Inode 19792343, i_blocks is 717168, should be 717176. Fix? yes
    Inode 19792344, i_blocks is 717168, should be 717176. Fix? yes
    Inode 19792345, i_blocks is 717128, should be 717136. Fix? yes
    Inode 19792347, i_blocks is 717136, should be 717144. Fix? yes
    Inode 19792348, i_blocks is 717136, should be 717144. Fix? yes
    Inode 19792349, i_blocks is 717176, should be 717184. Fix? yes
    Inode 19792350, i_blocks is 717128, should be 717136. Fix? yes
    Inode 19792351, i_blocks is 717152, should be 717160. Fix? yes
    Inode 19792352, i_blocks is 717152, should be 717160. Fix? yes
    Inode 19792353, i_blocks is 717136, should be 717144. Fix? yes
    Inode 19792354, i_blocks is 717136, should be 717144. Fix? yes
    Inode 19792355, i_blocks is 717152, should be 717160. Fix? yes
    Inode 19792356, i_blocks is 717144, should be 717152. Fix? yes
    Inode 19792384, i_blocks is 717184, should be 717192. Fix? yes
    Inode 19792385, i_blocks is 717176, should be 717184. Fix? yes
    Inode 19792386, i_blocks is 717200, should be 717208. Fix? yes
    Inode 19792387, i_blocks is 717096, should be 717104. Fix? yes
    Inode 19792388, i_blocks is 717192, should be 717200. Fix? yes
    Inode 19792389, i_blocks is 717184, should be 717192. Fix? yes
    Inode 19792390, i_blocks is 717144, should be 717152. Fix? yes
    Inode 19792391, i_blocks is 717192, should be 717200. Fix? yes
    Inode 19792392, i_blocks is 717168, should be 717176. Fix? yes
    Inode 19792393, i_blocks is 717168, should be 717176. Fix? yes
    Inode 19792394, i_blocks is 716904, should be 716912. Fix? yes
    Inode 19792395, i_blocks is 717192, should be 717200. Fix? yes
    Inode 19792396, i_blocks is 717200, should be 717208. Fix? yes
    Inode 19792397, i_blocks is 717168, should be 717176. Fix? yes
    Inode 19792398, i_blocks is 717192, should be 717200. Fix? yes
    Inode 19792399, i_blocks is 717216, should be 717224. Fix? yes
    Inode 19792400, i_blocks is 717176, should be 717184. Fix? yes
    Inode 19792401, i_blocks is 717192, should be 717200. Fix? yes
    Inode 19792402, i_blocks is 717184, should be 717192. Fix? yes
    Inode 19792403, i_blocks is 717192, should be 717200. Fix? yes
    Inode 19792404, i_blocks is 717184, should be 717192. Fix? yes
    Inode 19792405, i_blocks is 717184, should be 717192. Fix? yes
    Inode 19792406, i_blocks is 717160, should be 717168. Fix? yes
    Inode 19792407, i_blocks is 717272, should be 717280. Fix? yes
    Inode 19792408, i_blocks is 717192, should be 717200. Fix? yes
    Inode 19792409, i_blocks is 717184, should be 717192. Fix? yes
    Inode 19792438, i_blocks is 712920, should be 712928. Fix? yes
    Inode 19792439, i_blocks is 712872, should be 712880. Fix? yes
    Inode 19792440, i_blocks is 712864, should be 712872. Fix? yes
    Inode 19792441, i_blocks is 712872, should be 712880. Fix? yes
    Inode 19792442, i_blocks is 712888, should be 712896. Fix? yes
    Inode 19792443, i_blocks is 712880, should be 712888. Fix? yes
    Inode 19792444, i_blocks is 712864, should be 712872. Fix? yes
    Inode 19792445, i_blocks is 712896, should be 712904. Fix? yes
    Inode 19792446, i_blocks is 712928, should be 712936. Fix? yes
    Inode 19792447, i_blocks is 712904, should be 712912. Fix? yes
    Inode 19792448, i_blocks is 712896, should be 712904. Fix? yes
    Inode 19792449, i_blocks is 712864, should be 712872. Fix? yes
    Inode 19792450, i_blocks is 712872, should be 712880. Fix? yes
    Inode 19792451, i_blocks is 717960, should be 717968. Fix? yes
    Inode 19792452, i_blocks is 712864, should be 712872. Fix? yes
    Inode 19792453, i_blocks is 712872, should be 712880. Fix? yes
    Inode 19792454, i_blocks is 712880, should be 712888. Fix? yes
    Inode 19792455, i_blocks is 712880, should be 712888. Fix? yes
    Inode 19792456, i_blocks is 712904, should be 712912. Fix? yes
    Inode 19792457, i_blocks is 712904, should be 712912. Fix? yes
    Inode 19792458, i_blocks is 712912, should be 712920. Fix? yes
    Inode 19792459, i_blocks is 712912, should be 712920. Fix? yes
    Inode 19792460, i_blocks is 712904, should be 712912. Fix? yes
    Inode 19792461, i_blocks is 712872, should be 712880. Fix? yes
    Inode 19792462, i_blocks is 712904, should be 712912. Fix? yes
    Inode 19792463, i_blocks is 712864, should be 712872. Fix? yes
    Inode 19792492, i_blocks is 712888, should be 712896. Fix? yes
    Inode 19792493, i_blocks is 712880, should be 712888. Fix? yes
    Inode 19792494, i_blocks is 712872, should be 712880. Fix? yes
    Inode 19792495, i_blocks is 712888, should be 712896. Fix? yes
    Inode 19792496, i_blocks is 712904, should be 712912. Fix? yes
    Inode 19792497, i_blocks is 712880, should be 712888. Fix? yes
    Inode 19792498, i_blocks is 712896, should be 712904. Fix? yes
    Inode 19792499, i_blocks is 712872, should be 712880. Fix? yes
    Inode 19792500, i_blocks is 712864, should be 712872. Fix? yes
    Inode 19792501, i_blocks is 712880, should be 712888. Fix? yes
    Inode 19792502, i_blocks is 712896, should be 712904. Fix? yes
    Inode 19792503, i_blocks is 712888, should be 712896. Fix? yes
    Inode 19792504, i_blocks is 712880, should be 712888. Fix? yes
    Inode 19792505, i_blocks is 712880, should be 712888. Fix? yes
    Inode 19792506, i_blocks is 712896, should be 712904. Fix? yes
    Inode 19792507, i_blocks is 712880, should be 712888. Fix? yes
    Inode 19792508, i_blocks is 712880, should be 712888. Fix? yes
    Inode 19792509, i_blocks is 712856, should be 712864. Fix? yes
    Inode 19792510, i_blocks is 712872, should be 712880. Fix? yes
    Inode 19792511, i_blocks is 712888, should be 712896. Fix? yes
    Inode 19792512, i_blocks is 712904, should be 712912. Fix? yes
    Inode 19792513, i_blocks is 712872, should be 712880. Fix? yes
    Inode 19792514, i_blocks is 540496, should be 540504. Fix? yes
    Inode 19792515, i_blocks is 712872, should be 712880. Fix? yes
    Inode 19792516, i_blocks is 712856, should be 712864. Fix? yes
    Inode 19792517, i_blocks is 712872, should be 712880. Fix? yes
    Inode 19792547, i_blocks is 711976, should be 711984. Fix? yes
    Inode 19792548, i_blocks is 712000, should be 712008. Fix? yes
    Inode 19792549, i_blocks is 711976, should be 711984. Fix? yes
    Inode 19792550, i_blocks is 711976, should be 711984. Fix? yes
    Inode 19792551, i_blocks is 711968, should be 711976. Fix? yes
    Inode 19792552, i_blocks is 711992, should be 712000. Fix? yes
    Inode 19792553, i_blocks is 711992, should be 712000. Fix? yes
    Inode 19792554, i_blocks is 711984, should be 711992. Fix? yes
    Inode 19792555, i_blocks is 711984, should be 711992. Fix? yes
    Inode 19792556, i_blocks is 712000, should be 712008. Fix? yes
    Inode 19792557, i_blocks is 711984, should be 711992. Fix? yes
    Inode 19792558, i_blocks is 711984, should be 711992. Fix? yes
    Inode 19792559, i_blocks is 711984, should be 711992. Fix? yes
    Inode 19792560, i_blocks is 711992, should be 712000. Fix? yes
    /dev/mapper/c-c: 5064/30285824 files (1.0% non-contiguous), 333499778/484573184 blocks
ProSupport for Business
