jay2
Feb 10, 2012Aspirant
inproper shutdown every night like clockwork
We have the following ReadyNAS, have had it online from around 2006, its our backup server to our ReadyNAS Pro.
Its been a little work horse, I have no complaints.
Model: ReadyNAS NV [X-RAID]
Serial: 000da201022b
Firmware: RAIDiator 4.1.6 [1.00a043]
Memory: 256 MB [2.5-3-3-7]
Volume C: Online, X-RAID, 3 disks, 40% of 552 GB used
As of late I'm getting an inproper shutdown every night like clockwork, "02:23:52 CST ". This is where it gets more fun, our ReadyNAS pro model showes an "system up" message about the same time as well, both are on the same UPS. I will show a portion from each ReadyNAS below. I have the logs from each machine, just need to fiqure how to upload them if that will help as well, or can cut and paste from the logs if you can tell what one you want.
Thanks, Jay
Fri Feb 10 05:19:46 CST 2012 RAID sync finished on volume C. The volume is now fully redundant.
Fri Feb 10 02:34:23 CST 2012 System is up.
Fri Feb 10 02:24:23 CST 2012 RAID sync started on volume C.
Fri Feb 10 02:23:52 CST 2012 Improper shutdown detected. To ensure data integrity, a filesystem check should be performed by rebooting the NAS through Frontview with the volume scan option enabled.
Thu Feb 9 05:20:21 CST 2012 RAID sync finished on volume C. The volume is now fully redundant.
Thu Feb 9 02:35:04 CST 2012 System is up.
Thu Feb 9 02:24:59 CST 2012 RAID sync started on volume C.
Thu Feb 9 02:23:52 CST 2012 Improper shutdown detected. To ensure data integrity, a filesystem check should be performed by rebooting the NAS through Frontview with the volume scan option enabled.
Sat Feb 4 05:19:38 CST 2012 RAID sync finished on volume C. The volume is now fully redundant.
Sat Feb 4 02:34:09 CST 2012 System is up.
Sat Feb 4 02:24:08 CST 2012 RAID sync started on volume C.
Sat Feb 4 02:23:52 CST 2012 Improper shutdown detected. To ensure data integrity, a filesystem check should be performed by rebooting the NAS through Frontview with the volume scan option enabled.
Fri Feb 3 07:57:58 CST 2012 System is up.
Fri Feb 3 07:57:21 CST 2012 Volume scan found no errors.
Fri Feb 3 07:16:47 CST 2012 Rebooting device...
Fri Feb 3 07:16:47 CST 2012 Please close this browser session and use RAIDar to reconnect to the device. System rebooting...
Fri Feb 3 05:19:48 CST 2012 RAID sync finished on volume C. The volume is now fully redundant.
Fri Feb 3 02:34:26 CST 2012 System is up.
Fri Feb 3 02:24:19 CST 2012 RAID sync started on volume C.
Fri Feb 3 02:23:51 CST 2012 Improper shutdown detected. To ensure data integrity, a filesystem check should be performed by rebooting the NAS through Frontview with the volume scan option enabled.
Thu Feb 2 05:21:17 CST 2012 RAID sync finished on volume C. The volume is now fully redundant.
Thu Feb 2 02:36:00 CST 2012 System is up.
Thu Feb 2 02:25:53 CST 2012 RAID sync started on volume C.
Thu Feb 2 02:23:50 CST 2012 Improper shutdown detected. To ensure data integrity, a filesystem check should be performed by rebooting the NAS through Frontview with the volume scan option enabled.
Wed Feb 1 05:20:13 CST 2012 RAID sync finished on volume C. The volume is now fully redundant.
Wed Feb 1 02:35:00 CST 2012 System is up.
Wed Feb 1 02:24:56 CST 2012 RAID sync started on volume C.
Wed Feb 1 02:23:51 CST 2012 Improper shutdown detected. To ensure data integrity, a filesystem check should be performed by rebooting the NAS through Frontview with the volume scan option enabled.
Thu Jan 26 15:53:34 CST 2012 RAID sync finished on volume C. The volume is now fully redundant.
Thu Jan 26 13:08:07 CST 2012 System is up.
Thu Jan 26 12:58:09 CST 2012 RAID sync started on volume C.
Thu Jan 26 12:55:49 CST 2012 Improper shutdown detected. To ensure data integrity, a filesystem check should be performed by rebooting the NAS through Frontview with the volume scan option enabled.
Fri Nov 4 10:15:29 CDT 2011 System is up.
Fri Nov 4 10:04:57 CDT 2011 Powering off device
Fri Nov 4 10:04:57 CDT 2011 Please close this browser session and use RAIDar to reconnect to the device after it is powered back on. System powering off...
This is from the ReadyNAS Pro
Fri Feb 10 02:23:51 CST 2012 System is up.
Fri Feb 10 00:07:58 CST 2012 Backup finished. [Job 005]
Thu Feb 9 19:11:27 CST 2012 Backup finished. [Job 004]
Thu Feb 9 16:09:28 CST 2012 Backup finished. [Job 006]
Thu Feb 9 12:09:21 CST 2012 Backup finished. [Job 006]
Thu Feb 9 08:09:30 CST 2012 Backup finished. [Job 006]
Thu Feb 9 02:23:33 CST 2012 System is up.
Wed Feb 8 19:13:10 CST 2012 Backup finished. [Job 003]
Wed Feb 8 16:09:22 CST 2012 Backup finished. [Job 006]
Wed Feb 8 12:09:23 CST 2012 Backup finished. [Job 006]
Wed Feb 8 08:09:18 CST 2012 Backup finished. [Job 006]
Tue Feb 7 19:12:51 CST 2012 Backup finished. [Job 002]
Tue Feb 7 16:09:28 CST 2012 Backup finished. [Job 006]
Tue Feb 7 12:09:28 CST 2012 Backup finished. [Job 006]
Tue Feb 7 08:09:20 CST 2012 Backup finished. [Job 006]
Mon Feb 6 19:13:57 CST 2012 Backup finished. [Job 001]
Mon Feb 6 16:09:27 CST 2012 Backup finished. [Job 006]
Mon Feb 6 12:10:05 CST 2012 Backup finished. [Job 006]
Mon Feb 6 08:09:13 CST 2012 Backup finished. [Job 006]
Sat Feb 4 02:23:28 CST 2012 System is up.
Fri Feb 3 16:09:24 CST 2012 Backup finished. [Job 006]
Fri Feb 3 12:10:18 CST 2012 Backup finished. [Job 006]
Fri Feb 3 08:09:13 CST 2012 Backup finished. [Job 006]
Fri Feb 3 02:23:30 CST 2012 System is up.
Thanks, Jay
- StephenBGuru - Experienced UserIs something happening with your power? Sort of looks like it is going out, and then being restored around 2:23 am.
- PapaBear1ApprenticeWhat is strange to me is that on the NV, and improper shutdown would not result in a power up when power is restore. On the x-86 based model, yes, if they are manually shut down properly or have an improper shutdown, once power is restored to the unit, they will power back up and do a resync if necessary. If you improperly shut down or properly shut down an NV or NV+ (which I have), applying power will result in no action.
Just confirmed with my NV+ which at this time has no data. Unplugged it, plugged it back in and it just sat there. On reboot it started the synch process.
I also would be suspicious of the power, especially the UPS. But it is not every day, either. Any momentary or short term power disruption should be handled by the UPS.
How old are the batteries in the UPS?
Do you have another UPS that you can swap in for a test? - jay2Aspirant
PapaBear wrote: What is strange to me is that on the NV, and improper shutdown would not result in a power up when power is restore. On the x-86 based model, yes, if they are manually shut down properly or have an improper shutdown, once power is restored to the unit, they will power back up and do a resync if necessary. If you improperly shut down or properly shut down an NV or NV+ (which I have), applying power will result in no action.
The UPS battries are old, could be it, but would think it would take down a the other 2 servers as well. I'm not sure but maybe this old UPS goes into some kind of test every night and thats messing with it. It sure does seem like a power issue to me.
But as you noted, why is it booting back up, its so strange.
Will take it off the UPS and see what happens.
