gpaolo
Dec 03, 2020Luminary
Installing Domoticz on OS6 RN524
Hi all,
I have just upgraded my home heating system and I would like to install Domoticz on my NAS to monitor what is doing. I have followed the instructions on https://www.jaqb.gda.pl/pol/Spolecznosc/Blog/Domoticz-on-ReadyNAS , basically wget the file, then
cd /opt mkdir domoticz-2017-03-13 cd domoticz-2017-03-13 tar -zxf /tmp/domoticz_linux_x86_64.tgz
and then create file /lib/systemd/system/domoticz.service
[Unit] Description=Domoticz After=network.target [Service] ExecStart=/opt/domoticz/domoticz -daemon KillMode=process Restart=on-failure [Install] WantedBy=multi-user.target
and registered for automatic execution
systemctl enable domoticz systemctl start domoticz
Result: absolutely nothing happens. I try to connect to my NAS on port 8080 and I get no answer.
Does anyone has experience on this? I just found an old thread from 2015 on this forum but with no real information on the installation.
Thanks for your help!
I have seen a couple of posts here on the forum from people complaining about these same outdated libraries, so I tried another approach.
I found a website which keeps the old releases of Domoticz: https://domoticaboard.nl/index.php?PHPSESSID=91e63804132fc23afa50b81d16f04790&board=16.0
I have downloaded the latest V4 stable release, installed following the instructions on the website linked on the first post and it worked straight away.
So, until OS6 is updated with the newer linux libraries, it looks like the only way to go is to use the previous version of Domoticz.
I hope it helps other people that might want to try this program.
- gpaoloLuminary
Uhh ok, I get something looking at the status:
root@MY_NAS_NAME:/opt/domoticz# systemctl status domoticz ● domoticz.service - Domoticz Loaded: loaded (/lib/systemd/system/domoticz.service; enabled; vendor preset: enabled) Active: failed (Result: start-limit-hit) since Thu 2020-12-03 18:1 1:45 GMT; 16min ago Process: 31740 ExecStart=/opt/domoticz/domoticz -daemon (code=exited, status=127) Main PID: 31740 (code=exited, status=127) Dec 03 18:11:45 MY_NAS_NAME systemd[1]: domoticz.service: Main process exited, code=exited, status=127/n/a Dec 03 18:11:45 MY_NAS_NAME systemd[1]: domoticz.service: Unit entered failed state. Dec 03 18:11:45 MY_NAS_NAME systemd[1]: domoticz.service: Failed with result 'exit-code'. Dec 03 18:11:45 MY_NAS_NAME systemd[1]: domoticz.service: Service hold-off time over, scheduling restart. Dec 03 18:11:45 MY_NAS_NAME systemd[1]: Stopped Domoticz. Dec 03 18:11:45 MY_NAS_NAME systemd[1]: domoticz.service: Start request repeated too quickly. Dec 03 18:11:45 MY_NAS_NAME systemd[1]: Failed to start Domoticz. Dec 03 18:11:45 MY_NAS_NAME systemd[1]: domoticz.service: Unit entered failed state. Dec 03 18:11:45 MY_NAS_NAME systemd[1]: domoticz.service: Failed with result 'start-limit-hit'.
I guess I need to ask on their forum then, it looks like it's more a problem on the service... am I right?
- SandsharkSensei
Exit code 127 is "unknown command". I suspect there is a dependancy issue and that the program requires something that's not installed on the NAS. Perhaps there is a "verbose" mode for Domoticz or a method to turn on a debugging log that could give you more help.
- gpaoloLuminary
I see... ok thanks, I have asked also on their forum, I'll see if I can get some more detail. If I get a solution I'll post it here too in case someone else needs it.
I was a bit surprised that it was not in the applications of the NAS, it seems extremely popular for other brands, but barely nothing for ReadyNAS...
