tony359
Mar 20, 2014Apprentice
Intermittent transfers through Virgin Superhub [SOLVED]
Hi all, I have a little problem with my Virgin SuperHub (should be I, not II). What happens is I lose communication with the ReadyNAS every few minutes. I am playing a movie right now, it stops ...
tony359
Mar 21, 2014Apprentice
Ok, I believe it's sorted.
Apparently my Virgin SuperHub (it's a Netgear router inside) did not have an MTU set. I set 1500 manually and all looks good.
I'm assuming those little drops are normal, after all the average speed is 99.3MB/s.
What is funny is when I set the router to an MTU of 1492. It worked, but at a reduced speed. Then, without doing anything, it stepped up to max speed!
Ping is now 100% ok, no communication errors.
If nobody has nothing to add, I'll consider the case as solved?
Thanks for thinking of replying! ;)
