tony359
Mar 20, 2014Apprentice
Intermittent transfers through Virgin Superhub [SOLVED]
Hi all, I have a little problem with my Virgin SuperHub (should be I, not II). What happens is I lose communication with the ReadyNAS every few minutes. I am playing a movie right now, it stops ...
Mar 21, 2014Guru - Experienced User
Did you set the MTU on the NAS? or the router?
Did you use ping to find the actual MTU of the network?
