tony359
Mar 20, 2014Apprentice
Intermittent transfers through Virgin Superhub [SOLVED]
Hi all, I have a little problem with my Virgin SuperHub (should be I, not II). What happens is I lose communication with the ReadyNAS every few minutes. I am playing a movie right now, it stops ...
tony359
Mar 21, 2014Apprentice
Hi, thanks for your reply
The Router did not have an MTU set, the field was blank, have no idea what the value being used was.
No, I did not check with ping, but I was looking into it. There is something I don't understand though: when running the tests, what am I actually testing? Am I testing my ISP network? Am I setting the proper MTU so my network has the best possible MTU suitable for my ISP network?
I have just checked, on my PC the "best" MTU is 1500 and happens to be set to 1500. How come on my laptop the best MTU should be 1300?
UPDATE: uff, just ignore me! I was VPN'ed somewhere else and I had forgotten it! Everybody happens to be happy with 1500 then! :)
