Chris_Von_Bron
Aug 22, 2011Aspirant
Iomega Prestige 2TB not detected by ReadyNAS NV+
I’ve formatted a brand new Iomega Prestige 2GB external HD USB3.0 to NTFS (I know I would only get USB 2.0 speed). Problem is that the Nas won’t recognise the drive. The NV+ (latest firmware 4.1.7) ...
arjoseph1
Aug 22, 2011Tutor
Can you try to reformat it to FAT then check if it will be detected under volume settings. In the event that the drive will detected, try to reformat it to EXT3 on frontview.
