edmundwatson
Sep 08, 2012Aspirant
Largest Drive addable to Duo V2
What is the largest drive that can be installed to a Duo V2?
and out of curiosity what is limiting it to that size?
Thanks,
Thanks,
The largest drive on the HCL is 3 TB (http://www.readynas.com/?page_id=82).edmundwatson wrote: What is the largest drive that can be installed to a Duo V2?
Thanks,
A 4 TB drive could probably be installed and work. Though there's a risk that the drive might not be compatible, and Netgear will generally deny support if the drives are not on the HCL. - edmundwatsonAspirantCool, thanks you for reply.
So it seems like no readynas yet supports a 4TB - StephenBGuru - Experienced User
Correct. Although a couple of people have installed them anyway (viewtopic.php?f=83&t=58447)edmundwatson wrote: Cool, thanks you for reply.
So it seems like no readynas yet supports a 4TB - PapaBear1ApprenticeWhen there is a viable pool of 4TB drives, Netgear will probably test them. There is no hurdle as there was between 2TB and 3TB.
