prime00's avatar
prime00
Follower
Aug 04, 2010
LCD on NV+ shows volume not hostname.
Hi!
Maybe this issue has been condsidered in another thread but I don't find it.
In the LCD-display I can see the correct IP-address and volume size, but not the host name.
Is there any setting to change this?
I have a NV+ with firmware version RAIDiator 4.1.7-T42 [1.00a043], 4 x 2TB WDC WD20EARS-00S8B1.
In Frontview and RAIDar 4.3.0 all discs are present, but on the NV+ front the LED indicating disc 2 isn't lit.
Thanks in advance.
/P
  • The LCD will only show the IP, not hostname.
    If FrontView/RAIDar shows Disk 2 healthy, it might be the LED board in the chassis having problems itself. You can contact technical support (numbers below) to inquire about a chassis RMA if needed.
  • I think that the LCD used to display hostname, but maybe that was changed in a RAIDiator update.
ProSupport for Business
