MindBender
Mar 03, 2011Aspirant
Link aggregation (LACP) problems
I have just installed my ReadyNAS Pro 6 and yesterday I bumped into a couple of strange problems. First of all my Orb server was reported unreachable on my iPad and next one of my Windows machines was...
Oct 29, 2012Guru - Experienced User
It's not obvious to me either, perhaps you should clarify (I suspect you meant it "should be..." something else).
MindBender wrote: It turned out that I had configured a static link aggregation, which is nog supported by ReadyNAS. It should be a static link aggregation, and the difference is not obvious in my Switch's web front-end.
