Johncaputo
Sep 04, 2019Tutor
Loading please wait loop
When i attempt to log onto our cloud it just says loading please wait and it keeps refreshing and trying on its on in a loop. I reset our cloud and network and this didn't solve the problem. The lack...
Sep 04, 2019Guru - Experienced User
Not sure if you want the community to help, or if you just want to express your opinion on Netgear.
If you want community help - can you tell us what "our cloud" is, and what ReadyNAS you are using? The Ultra isn't compatible with ReadyCloud.
Sandshark
Sep 04, 2019Sensei
There are other VPN solutions to accessing your NAS remotely, you don't have to use ReadyCloud. I use ZeroTier. And if you aren't accessing it remotely, why are you using ReadyCloud at all?
- JohncaputoSep 05, 2019Tutor
Honestly im not sure and im researching zerotier right now. Thank you for your input
