Johncaputo
Sep 04, 2019Tutor
Loading please wait loop
When i attempt to log onto our cloud it just says loading please wait and it keeps refreshing and trying on its on in a loop. I reset our cloud and network and this didn't solve the problem. The lack...
Sep 04, 2019Guru - Experienced User
Not sure if you want the community to help, or if you just want to express your opinion on Netgear.
If you want community help - can you tell us what "our cloud" is, and what ReadyNAS you are using? The Ultra isn't compatible with ReadyCloud.
Johncaputo
Sep 05, 2019Tutor
Alittle bit of both because it seems like a crime to have to pay for support for a faulty product. I didn't sign up to be a beta tester. You are correct i couldn't find my model in the drop down menu when i created this thread. The model is RN42200. I would refer to tech support but they think they can charge me for fixing probelms they brought on to me. This is day two of loading please wait loop when signing into readycloud.
- StephenBSep 05, 2019Guru - Experienced User
That's because the RN 422 isn't in the list (though the 424, 426, and 428 all are).
ChristineT , JohnCM_S Marc_V: can you take care of this?
Honestly I can't recommend using ReadyCloud for a business-critical application. If you are trying to do that I think you will get very frustrated.
If you just want remote access, then deploying a VPN router is probably the best way to go - that would give remote workers full access to corporate network (including the NAS). ZeroTier can also work for that.
If you need the other services that ReadyCloud offers, then I'd suggest OwnCloud or NextCloud. Both need ports forwarded, and you need either a DNS or DDNS name for the router IP. Once done, the management is under your control, with no reliance on cloud services.
