icyvran
Mar 04, 2014Tutor
Logitech UE Music Library
Hello,
I would like to know if someone could make an app for "Logitech UE Music Library". You can find the apps for legacy ReadyNAS devices here: http://downloads.slimdevices.com/nightly/?ver=10.0
Thanks
:D
Thanks
:D
- mrfusionAspirantBought a UE smart Radio to someone of my family which has a readynas 102 using OS6.
unfortunately as icyvran told there is no direct package for OS6.
icyvran can you detail your installation process because I don't understand why you first install/uninstall LMS?
Is it to ensure to have the dependencies installed?
I guess you installed the package with dpkg -i ?
To Superpoussin: that would be wonderful to do the package for OS6 as it is the only one missing.
I installed the package available on the link on my duo to test the smart radio and it was working great. - icyvranTutorI have a solution for my own question :D
In order to install the Logitech UE Music Library on a ReadyNAS with OS6 version 6.1.8 you have to:- 1. Install and then uninstall the app "Logitech Media Server" that is available for OS6
2. Access the ReadyNAS via SSH
3. Install via SSH the "UE Music Library: Debian Installer Package " that is available in http://downloads.slimdevices.com/nightly/?ver=10.0
Then you can access the server settings on http://192.168.1.8:3546/
Good luck! :)
