max_kublin
May 13, 2014Tutor
Looking for spare Fan Crown AGE08015B12V for Pro 6
Hi, It appears that the CPU Fan of my Readynas Pro 6 is going to fail in the near future. The Fan makes some "clicking noise" - I already checked that no dust/cable is producing the noise. i con...
max_kublin
May 13, 2014Tutor
I need a 80 x 80 x 15 mm Fan - the NF-S12A FLX is 120 mm
I considered buying a German brand - EBM Papst - but they have no Fan that is just 15 mm high :-(
The same issue is with the NF brand: They have a 80 mm Fan but it is 25 mm high :-(
See: http://www.noctua.at/main.php?show=productview&setlng=en&products_id=9
Has anyone replaced the AGE08015B12V (80x80x15mm) Fan yet?
