max_kublin
May 13, 2014Tutor
Looking for spare Fan Crown AGE08015B12V for Pro 6
Hi, It appears that the CPU Fan of my Readynas Pro 6 is going to fail in the near future. The Fan makes some "clicking noise" - I already checked that no dust/cable is producing the noise. i con...
fastfwd
May 13, 2014Virtuoso
max_kublin wrote: I need a 80 x 80 x 15 mm Fan .... Has anyone replaced the AGE08015B12V (80x80x15mm) Fan yet?
You're right; there are very few 15mm fans available, let alone 15mm fans with airflow specs as good as that one.
I replaced mine with a Noctua NF-R8 PWM. It's a 25mm fan, but it fits if you slightly modify the shape of the ReadyNAS side panel with a hammer.
I'll take a photo of the side panel tonight and post it here.
