max_kublin
May 13, 2014Tutor
Looking for spare Fan Crown AGE08015B12V for Pro 6
Hi, It appears that the CPU Fan of my Readynas Pro 6 is going to fail in the near future. The Fan makes some "clicking noise" - I already checked that no dust/cable is producing the noise. i con...
max_kublin
May 13, 2014Tutor
Finally I was able to locate a few 80x80x15 mm Fans in the Internet, e.g.
See: http://www.blacknoise.com/downloads/old/datasheets_old/BSP_info_final.pdf
Will need some time to sort out which model electrically fits best, but I have some hope that I will not need a hammer to replace the Fan ....
