max_kublin
May 13, 2014Tutor
Looking for spare Fan Crown AGE08015B12V for Pro 6
Hi, It appears that the CPU Fan of my Readynas Pro 6 is going to fail in the near future. The Fan makes some "clicking noise" - I already checked that no dust/cable is producing the noise. i con...
max_kublin
May 16, 2014Tutor
Hi Folks,
Today I replaced my Fan with the following model:
Noiseblocker NB-BlackSilentPRO PC-P 80x80x15mm
Details: http://www.watercoolinguk.co.uk/p/Noiseblocker-NB-BlacksilentPRO-PCP-80x80x15mm_38569.html
result: perfect!
Fits 100% and is very silent!
My issue is solved, and definitely no hammer was needed :-)
- Max
result: perfect!
- Max
