max_kublin
May 13, 2014Tutor
Looking for spare Fan Crown AGE08015B12V for Pro 6
Hi, It appears that the CPU Fan of my Readynas Pro 6 is going to fail in the near future. The Fan makes some "clicking noise" - I already checked that no dust/cable is producing the noise. i con...
max_kublin
May 19, 2014Tutor
Good points - Thanks!
Concerning temperature: Fortunately, *this* (=one of three!) ReadyNAS PRO 6 is located in the cellar, which is a cool place.
The (SYS) temperature has indeed raised a bit, but it is still far away from the maximum.
RAID scrubbing is scheduled every week, but no other load happens on this NAS, because it is a 100% mirror (backup)
of my "primary" ReadyNAS PRO 6.
The current "solution" gives me time to continue my search for another replacement fan with better specs.
I will keep you posted about the Progress.
- Max
- Max
