iceweasel
Sep 06, 2024Tutor
Looking for thought on SSH performance on RN systems
Having issues with SSH connections on all the ReadyNAS systems running 6.10.10.
The problem is all the connection stages take close to 2 minutes to complete. It's insane and I can't figure out why.
This occurs on 3 systems (RN204 and RN104) so yes low-powered but this is crazy slow.
I've tried with clients (ssh, putty, and python using paramiko) on Win7, Win10, Win11, Linux (Kali, Parrot, and Ubuntu) and same results every time. Slow as can be. Once the session is live the response isn't bad it's just the connecting is soooo slow.
The python script connects to the server at root@IP which takes almost a minute and half to get to a prompt, then issuing an "ls /" which takes another minute to complete.
The putty and ssh connections are very similar, in that the password challenge is presented nearly instantly, but then takes a minutes for the banner it's nearly 3 minutes! Windows SSH is identical timing.
All the demos are connecting to the RN204, and the same happens with the RN104s which are just as fast, ummmm slow. There are a couple of videos showing top on the parrot sessions.
Win 10 python - https://streamable.com/08u8ks
Parrot python - https://streamable.com/601lx0
Parrot SSH - https://streamable.com/r5n0c9
Parrot top - https://streamable.com/7x0oak
Any thoughts on how to get SSH to respond in less time?
If you
- connect with Windows ssh
- log in
- immediately log out when you get the command prompt (after your password entry)
- reconnect with Windows ssh
Does the reconnect also take 2-3 minutes?
Also, do you have disk spindown enabled on the NAS?
Thanks StephenB, good thinking on the disk spin down and while it's enabled it's not a factor. AFAIK the ssh client (always running in the background) doesn't need disk access and is just like any other background task. I confirmed the device doesn't spin up the drive on ssh connect until you start interacting with the OS.
I tried your test and found the exact same response both times, nearly 3 minutes with connect, disconnect, connect:
C:\Users\iceweasel>ssh root@192.168.1.200
root@192.168.1.200's password:
Welcome to ReadyNASOS 6.10.10
Last login: Fri Sep 6 14:27:30 2024 from readynas-204
root@ReadyNAS-204:~# exit
logout
Connection to 192.168.1.200 closed.
Last login: Sat Sep 7 10:19:10 2024 from thefactory
logout
Last login: Sat Sep 7 10:21:51 2024 from thefactory
logout
C:\Users\iceweasel>You may have noticed the first connect message shows the prior connect from the readynas itself. I had been doing testing with tunneling with paramiko to work around the slow connect. But that got me thinking...what if I ssh from the RN to the RN?
If from an active ssh session on the RN I ssh at the LAN address I get the same results
If I try again but accessing with localhost (127.0.0.1) the connection process is nearly instant. Which would suggest there's something on the LAN interfering? I'm not sure of that but may need to try a direct connect PC->RN and see if things go faster but that will take some work and I'm hoping there may be something else easier than reconfiguring the NAS for a test.
I also checked that only the required system tools are enabled in the web interface.
There's an interesting tangent problem I need to address with uninstalling some old apps, but none of those are running there're just taking up disk space and the UI remove fails. But I'll save that until this gets resolved.
FWIW,I see the banner in a second or so on my RN102 after I enter the password.
So this could be something on your network (perhaps internet security software???).
