railfrog
Oct 07, 2011Aspirant
Make and Model
Hi Looking at the readynas duo. Am i right in thinking that the different models, 2210, 2120 etc are just different sizes/set up of hard disk, but the actual unit is exactly the same in all the ...
Oct 07, 2011Guru - Experienced User
Yes. Though there are a couple of other 2-slot ReadyNAS products (an ultra and a pro) which are much faster than the Duo. BTW, if you want to use drives bigger than 2 TB, you need the ultra or pro products.
RND2xxx is the sparc-based two slot DUO
RNDP2xxx, RNDU2xxx are x86 based.
