eton's avatar
eton
Luminary
Apr 15, 2023
Making a folder appear as a volume in OS 6 GUI?
If a folder is created via SSH under /data/ like /data/New-folder, it will not appear as a normal share in ReadyNAS OS 6's web GUI. What needs to be edited to make that folder become a normal share? Specifically which terminal commands needs to be executed and which files needs to be edited?
  • StephenB's avatar
    Among other things, a share is a BTRFS subvolume, and not an ordinary folder.
    The best thing is to rename new-folder to a temporary name, and then create the share properly using the web ui.  Then copy the contents into the share, and delete the original folder.  You can do the copy from ssh using --ref-link - that will transfer more quickly, and won't double the disk space.
    • eton's avatar
      eton
      Luminary
      Ah, BTRFS subvolume!
      I know how to create a share via the web GUI. The question is how to dot it via terminal.
      How is this accomplished?
      Please reply with full command example for `--ref-link`.
      • StephenB's avatar
        eton wrote:
        I know how to create a share via the web GUI. The question is how to do it via terminal.
        Not sure how to set up everything the ReadyNAS application needs, so my basic advice is don't.
        It's an option for cp.
ProSupport for Business
