eton
Apr 15, 2023Luminary
Making a folder appear as a volume in OS 6 GUI?
If a folder is created via SSH under /data/ like /data/New-folder, it will not appear as a normal share in ReadyNAS OS 6's web GUI. What needs to be edited to make that folder become a normal share? ...
eton
Ah, BTRFS subvolume!
I know how to create a share via the web GUI. The question is how to dot it via terminal.
How is this accomplished?
Please reply with full command example for `--ref-link`.
Apr 15, 2023Guru - Experienced User
eton wrote:
I know how to create a share via the web GUI. The question is how to do it via terminal.
Not sure how to set up everything the ReadyNAS application needs, so my basic advice is don't.
It's an option for cp.
- etonApr 16, 2023Luminary
I manually created a btrfs subvolume:
btrfs subvolume create /data/cli-test
chown guest:guest /data/cli-testAnd added it to these config files:
/etc/frontview/samba/Shares.conf
/etc/snapper/configs/10
/etc/minidlna.conf
And restarted needed services. The subvolume/share is accessible over the network but still doesn't show up in web admin.
- StephenBApr 16, 2023Guru - Experienced User
There's also an SQL database, and I am guessing that it needs to be added there.
Indeed!
# find / -not -path "/data/*" -not -path "/media/*" -not -path "/run/*" -type f -iname "*.sql"
/usr/share/mysql/mysql_system_tables_data.sql
/usr/share/mysql/mysql_system_tables.sql
/usr/share/mysql/fill_help_tables.sql
/usr/share/mysql/mysql_test_data_timezone.sql
