eton
Apr 15, 2023Luminary
Making a folder appear as a volume in OS 6 GUI?
If a folder is created via SSH under /data/ like /data/New-folder, it will not appear as a normal share in ReadyNAS OS 6's web GUI. What needs to be edited to make that folder become a normal share? ...
Sandshark
Apr 19, 2023Sensei
There are also a lot of hidden files that have to be there. Netgear did not create a command line utility for creating a share, likely because you also need to set up sharing options. Is there a reason you need to do it from SSH? There is a script (I know StephenB has a link for it) that will scan the BTRFS sub-volumes and update the hidden files and databases. But you'd still have to set permissions to get access unless you are logging in as admin.
tigerten
Apr 19, 2023Luminary
look at here:
you can create volume under SSH for ReadyDATA. I would assume possible with ReadyNAS as well.
https://community.netgear.com/t5/ReadyDATA/Install-OS6/m-p/1531523/highlight/true#M483
- StephenBApr 20, 2023Guru - Experienced User
Yes.
Netgear has a utility called rnutil. It has quite a few "personalities"
event_push push a system event to the UI get_disk_info print a list of all attached disks and disk information check_ups_drv check and possibly start network ups drivers rn_shutdown shutdown readynasd and system gracefully rn_lcd LCD display remote_access start a remote access session for tech support volume_util perform volume operations mkhomedir_helper home subvolume creator for PAM disk_event_handler handler for disk events hotplug_event notifier for hotplug events md_event notifier for MD RAID events start_raids start all MD RAID arrays volume_schedule start volume schedule job spindown_schedule start spindown schedule job backup_md backup MD RAID superblocks bit_rot_event bit rot events firmware_update check for firmware update apt_wait Wait for an APT lock to release create_system_log Create system log archive diagnostics Run system diagnostics blink Locate the NAS with LEDs bluetooth_event Bluetooth events dump_sysflags List systype flags or check if flag is set for system clamav_event ClamAV events antivirus_scan_rootfscan antivirus in rootfsThe personality is determined by the executable file name. For instance, /usr/bin/volume_util is a link to rnutil, and when you execute the link you can run the volume_util command set. (you can alternatively run rnutil volume_util directly).
The volume_util commands are:
root@NAS:~# volume_util help Usage: volume_util [-c NAME] [-c NAME D1,..,DN] [-c NAME LEVEL D1,..,DN] [-c NAME LEVEL D1,..,DN KEY_FILE] [-d NAME|UUID] [-x NAME|UUID] [-e] [-e TYPE] [-v NAME LEVEL D1,...,DN] [-f NAME DISK] [-S DISK] [-F DISK] [-s TYPE..] -c Create pool NAME is the desired pool name LEVEL is the desired RAID level (0,1,5,6,10) D1,..,DN is the list of disk channels to use, zero-based you may specify the disk by controller and channel, so '0,1' means chassis 0, channels 0 and 1 '1:3,1:4' means chassis 1, channels 3 and 4 if you do not specify any channels, all available channels will be used KEY_FILE is the encryption key passphrase file for encrypted volumes -d Delete pool NAME is the desired pool name UUID is the UUID of the desired pool -x Export pool NAME is the desired pool name UUID is the UUID of the desired pool -e Expand pool TYPE is one of 'auto', 'expand', 'extend', or 'xraid' auto - automatically do all forms of expansion expand - expand to fill all space on all current disks (disk replacement) extend - extend pool to use available new disks (disk addition) xraid - grow pool to use available space on some current disks (partial disk replacement) -f Flex-RAID add parity NAME is the desired pool name D1,..,DN is the list of disk channels to use, zero-based you may specify the disk by controller and channel, so '0,1' means chassis 0, channels 0 and 1 '1:3,1:4' means chassis 1, channels 3 and 4 -E Flex-RAID expand NAME is the desired pool name D1,..,DN is the list of disk channels to use, zero-based you may specify the disk by controller and channel, so '0,1' means chassis 0, channels 0 and 1 '1:3,1:4' means chassis 1, channels 3 and 4 -v Vdev expand pool NAME is the desired pool name LEVEL is the desired RAID level (0,1,5,6,10) D1,..,DN is the list of disk channels to use, zero-based you may specify the disk by controller and channel, so '0,1' means chassis 0, channels 0 and 1 '1:3,1:4' means chassis 1, channels 3 and 4 -S Make a disk a hot spare DISK is the disk channel to use, zero-based -F Format disk DISK is the disk channel to use, zero-based -r Automatically repair degraded pools -O Forcibly optimize swap array -s Show volume information TYPE is any combination of 'disk', 'raid', 'pool', or 'enclosure' separated by a space so '-s disk raid' would show disks and raidsWhat rnutil doesn't seem to have is a mechanism to create a public share.You can create a home folder for a user account with rnutil mkhomedir_helper - which is a specialized share, but not public.
root@NAS:~# mkhomedir_helper
Usage: mkhomedir_helper <username>
root@NAS:~#
There possibly could be some other tool that can create a public share, but I don't know what it is.
As Sandshark says, there is a repair script that Netgear support uses that might give you more clues.
If you download it to the NAS with wget, you will need to add the --no-check-certificate option.
- etonApr 20, 2023Luminary
Thanks StephenB!
Interesting command: rnutil, but I have never before encountered arguments being named personalities. Although the arguments in this case are sub programs.
I browsed through script, but could not find how a new share was made available in the web admin:
https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/-/blob/master/share_lun_ui_fix.sh
And there we had a real engineer at Netgear: Cody Cook https://codycook.us/#resume
It appears to be rebuilding config files in /volume/._shares/sharename
Looking at one of my shares, these are the files needed
root@NAS:/data/._share/Backup# ls -als total 44 0 drwxr-xr-x 1 root root 324 Apr 20 11:00 . 0 drwxr-xr-x 1 root root 482 Feb 28 16:41 .. 4 -rw-r--r-- 1 admin admin 179 Feb 28 16:41 afp.conf 4 -rw-r--r-- 1 admin admin 116 Apr 20 11:00 custom_snapshot_management.conf 4 -rw-r--r-- 1 admin admin 175 Apr 20 11:00 custom_snapshot_schedule.conf 4 -rw-r--r-- 1 root root 6 Feb 28 16:41 datasettype.conf 4 -rw-r--r-- 1 admin admin 65 Sep 23 2018 fs.conf 4 -rw-r--r-- 1 admin admin 113 Feb 28 16:41 ftp.conf 4 -rw-r--r-- 1 admin admin 110 Feb 28 16:41 nfs.conf 0 drwxr-xr-x 1 admin admin 2 Feb 22 2021 .pvcache 4 -rw-r--r-- 1 root root 8 Feb 28 16:41 recycle.conf 4 -rw-r--r-- 1 admin admin 138 Feb 28 16:41 samba.conf 4 -rw-r--r-- 1 root root 1 Feb 28 16:41 snapdir.conf 4 -rw-r--r-- 1 root root 14 Apr 20 11:00 snapshot.conf root@NAS:/data/._share/Backup#Not sure if that is all that is needed, but it is a start.
Yes, I know that each share has got settings in a hidden directory. In my case: /data/._share/{ShareName}
I copied settings from a share I made via web admin to my test share (created via CLI). But it still does not show up in web admin. Not even after reboot.
I think I have found where web admin stores shares info:
sqlite3 --header --column /var/readynasd/db.sq3 'select * from "share"' sqlite3 --header --column /var/readynasd/db.sq3 'select id,zfs_name,type,name,path from "share" Order by name' sqlite3 --header --column --separator "|" --list /var/readynasd/db.sq3 'select id,zfs_name,type,name,path from "share" Order by name' | column -t -s "|"And there are more database files in /var/readynasd/
# ls -lA /var/readynasd/ total 12384 -rw-r----- 1 root admin 8212480 Apr 20 21:16 db.sq3 -rw-r--r-- 1 root root 16384 Apr 20 21:26 event.sq3 -rw-r--r-- 1 root admin 131 Sep 27 2022 .flash_update_info -rw-r--r-- 1 root root 4406801 Apr 20 21:31 loadavg.dat -rw-r--r-- 1 root root 42 May 9 2020 .localsid -rw-r--r-- 1 root root 1589 Apr 18 22:11 pilgrim.list -rw-r--r-- 1 root root 8192 May 9 2020 smart.sq3 drwxr-xr-x 1 root root 168 May 9 2020 stats -rw-r--r-- 1 root root 7 Sep 27 2022 .update_from -rw-r--r-- 1 root root 15001 Apr 20 21:16 usage.datThe sq3 files are related to readynasd.Restart with systemctl restart readynasd
- SandsharkApr 21, 2023Sensei
If you aren't willing/able to create the share via the GUI, I don't know why you care that the share be visible in it. Studying that script told me a lot about the "under the hood" workings of a ReadyNAS share. But since the share is intended to find "lost" shares and make them visible to the GUI, I believe it should do the same with your share created via the back door,
- etonApr 21, 2023Luminary
Sandshark I am doing this out of curiosity. I am fine with creating new share via gui, but would like to know how to do it via cli. And it gets extra enticing when there is no publicly known method.
Yes I understand that that script solves a problem that is very close to this case. I found some interesting stuff there, but did not understand all of it.
- etonApr 22, 2023Luminary
I managed to make the BTRFS subvolume that was created via CLI visible in the web admin 😄
I added it like this
sqlite3 /var/readynasd/db.sq3 INSERT INTO share (id, zfs_name, type, volume_id, name, path, user_access, group_access, everyone_access, non_owner_delete, user_id, group_id, update_ts) VALUES (13, 'data/TestTest', 'share', 'data', 'TestTest', '/data/TestTest', 7, 7, 7, 0, 99, 99, CURRENT_TIMESTAMP); .exit - tigertenApr 24, 2023Luminary
Amazing expedition!
You might be able to figure out why the USB drive is not showing up as external under media with virtual ReadyNAS.
I can mount to a subvolume under DATA, but not under the default media/USB_HDD. Wee, I would say I can mount it to under media manually, but it does show up in the UI.
