kenjpn
Aug 05, 2019Follower
malfunction in folder access set up
We got the RN3138, and setup folders, users, and acces authorities. During this process, we encountered the following issue. 1.One user had no access authoriy, no loged in 2.He just input the I...
Retired_Member
Aug 06, 2019Hi kenjpn, one possible explanation for that malfunction might be, that you still have enabled "everybody" in the file access rights. You might want to check the concerned share and if that is the case disable "everybody" to let only users with valid accounts and passwords access your shares as intended.
Kind regards
- StephenBAug 06, 2019Guru - Experienced User
Of course allowing anonymous access (which is the default setting) would also have done this.
I am thinking this might be related to the timing. If the person opened the SMB session before you set the network permissions, then changing the network permissions might not close that open session (since authentication has already been done).
If that's what happened, then rebooting the NAS would have also terminated his access.
