ChristianoNL
Apr 21, 2011Aspirant
Memory test ReadyNAS Ultra 2
Good day everyone!
I have a question about the ReadyNAS Ultra 2 memory upgrade.
A couple of months ago I bought this new NAS for my home to backup, download and share files!
Today I’ve upgraded the memory of this NAS from 1 GB ASint Sodimm DDR3 1066 mhz to 2GB Corsair Sodimm DDR 1333 mhz.
2 Hours ago i started the memory test of this device, the pattern lit goes form
1. Disk 1 lit
2. Disk 2 lit
3. Power button lit
4. USB lit
I this the correct way to test my memory right, or is my memory bad?
I've searched this forum but i cannot find any information about the Ultra 2 to run memory test.
Thanks Alot!
Bye... :shock:
1. Disk 1 lit
2. Disk 2 lit
3. Power button lit
4. USB lit
Thanks Alot!
Bye... :shock:
- dannyleesmith80Aspiranthas any one tried the 4gb CT51264BC1067 as i am using the 2gb CT25664BC10 and it work fine i will get one next week and try it if not
- JarnoGGuideI tried the Kingston KTH-X3B/4G (4GB, 16 chips) last night and that one doesn't work.
- dannyleesmith80AspirantCT51264BC1339 4 GB DDR3 RAM its a 512 x 64 memory module from Crucial mite be the next option. It has 8 x chips seems to only accept modules with 8 x chips only by the look of it. at the moment I am using a 2gb crucial 256 x 64 at the moment and it works fine faster speed ram also 10600 its doing the job
- JarnoGGuideDo not work:
Kingston KVR1333D3S9/4G (4GB, 16 chips)
Nanya NT2GC64B8HA1NS-BE (2GB, 16 chips)
Elpida 2Rx8 PC3-10600S-9-10-F1 (2GB, 16 chips)
How's the Crucial memory working out? - dannyleesmith80Aspirantcrucial works well. haven't had a chance to try the 4gb out yet. but the 2gb works well that's the 8 chip 256x64
dannyleesmith80 wrote: CT51264BC1339 4 GB DDR3 RAM its a 512 x 64 memory module from Crucial mite be the next option.
I tried this as it was cheap as chips, under £15 quid delivered in the UK. It didn't work.
Have you tried any more yet, Danny?- dannyleesmith80Aspirantnot yet m8 just renovating our home as soon as i am done i will be trying to test more modules.
And will be listing and i do test. - EtzAspirantMaximum amount would be 2GB for Ultra, its Intel Atom Chipset limitation, 4GB memory max, allocated to two slots. (2x2GB)
But as you may already know, Ultra has only one slot available ;)
Thats why Crucial CT51264BC1067 4GB module wouldnt work.
I used 2GB module CT25664BC1067, and it works fine, passed all memtests and so on. :rofl: - besokareAspirantKingston KVR1333D3S8S9/2G works too. Had it for 1 week now and no errors.
http://www.kingston.com/dataSheets/KVR1333D3S8S9_2G.pdf
It has 8 chips in total, 4 on each side. - daveevans76AspirantI use my NAS to stream movies to APTV2. Is there a large gain to be had with upgrading from 1GB to 2GB for uploading and streaming content?
