sirgeek's avatar
sirgeek
Follower
May 11, 2013
Memory Upgrade For ReadyNAS 100-104
I hope this is the right place to post this, I APOLOGIZE IN ADVANCE IF IT IS NOT.
I just bought a ReadyNAS 104 and I want to increase the memory, but I haven't been able to open the case to do so.
Can someone please help me?
I would like to use some 2 GB DDR2 SODIMS left over from my MacBook upgrade if possible. I need to get the case open first.
ALL ADVICE IS GRATEFULLY ACCEPTED, THIS IS MY FIRST NAS.
THANK YOU FOR YOUR KIND ASSISTANCE.
  • StephenB's avatar
    I'm not certain about the RN1xx, but the other ReadyNAS ARM systems have the memory soldered on. So I am thinking it is quite unlikely that you can add RAM.
    If it is possible, it would void the warranty.
  • It is likely the same board as the Duo v2, with upgraded CPU. Which means it is soldered on, no upgrades possible.
ProSupport for Business
