joso73's avatar
joso73
Follower
Nov 14, 2013
Migrate from Ultra 4 to 314
I have a Ultra 4 and I'm thinking about buying a 314. Can I move the harddrives from the Ultra 4 to the 314 and the data will be intact or do I have to backup the data first and restore it after I have moved the harddrives?
  • Hi
    Im in a similar position. I have just upgraded from an ultra to the 316
    I want to copy my files over but am unsure of the best way.
    Is it possible to directly connect the two using the second Ethernet?
    Can I copy on a folder basis?
    Currently I am copying data via a laptop which is the slowest means going but I note that one copied all files will work and be in the place I want.
    Cheers
    John
ProSupport for Business
