Hotrod1969
Feb 08, 2016Aspirant
Migration from Ultra2 to RN214, Drive swop
Hi, I have a ReadyNAS Ultra 2 [X-RAID2] running 2 x 2TB drives with RAIDiator 4.2.28 firmware. This has seen very good service but is now nearing capacity. I am thinking of upgrading to a RN214. M...
Feb 08, 2016Guru - Experienced User
The drive formatting is not compatible, so you will need to copy your data off to external storage if you want to reuse your existing drives.
Hotrod1969
Feb 16, 2016Aspirant
Many thanks. I think that my strategy will be then to run the new 214 with a single new drive, transfer the data from the Ultra and then swop the two Ultra drives into the 214 and reformat them. Can anyone envisage any snags ?
- StephenBFeb 16, 2016Guru - Experienced User
That should work, assuming no disk errors during the expansion.
Though I'd get new disks myself (perhaps larger) and use the ultra2 to back up critical files on the RN214.
