paulsb01
Apr 10, 2019Aspirant
MISSING Volume after OS reset
My 4 disk unit has been working flawlessly forever. 2 pair of drives set as redundant. Volume C and Volume D.
I needed to get into the Raidar page but no longer had my password, nothing worked ...
Apr 11, 2019Guru - Experienced User
paulsb01 wrote:
So I did the OS reset.
Did you do an OS reinstall (which would preserve the files on the C volume)? Or did you do a factory default, which wouldn't preserve the files or configuration?
If you did a factory default, then you'd only have one XRAID volume (larger than what you had before).
paulsb01
Apr 11, 2019Aspirant
os install. All I needed was the password reset.
