h0mer
Feb 25, 2019Tutor
mount_block_root +267 error RN516 out of warranty by 2 months
Owned and running my 516 since 2013. A true work horse.
I went to move the unit, properly shut it down, for some construction being done in my basement.
Plugged it in, turned it on, now...
Feb 25, 2019Guru - Experienced User
It might not be the chassis hardware.
Remove the disks (labeling by slot), and then insert a test disk (that you don't mind reformatting). Then try to do a factory default via the boot menu. See pages 120-121 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
Let us know if that procedure works.
h0mer
Feb 26, 2019Tutor
Also, I did try holding the reset button in and turning the unit on to get into boot mode. That does not work either.
