h0mer
Feb 25, 2019Tutor
mount_block_root +267 error RN516 out of warranty by 2 months
Owned and running my 516 since 2013. A true work horse.
I went to move the unit, properly shut it down, for some construction being done in my basement.
Plugged it in, turned it on, now...
h0mer
Feb 26, 2019Tutor
Thank you for your reply. Unfortunately, the unit will not boot or give me anything other than the error above whether the disks are in the chasis or not.
Feb 26, 2019Guru - Experienced User
Then it's likely to be the flash memory. USB recovery is the right solution, but it is a tricky procedure. Perhaps try again with a different flash drive.
Though I haven't needed to do a USB recovery myself, I've been told that it can be tricky to press the O.K. button at just the right moment.
