h0mer
Feb 25, 2019Tutor
mount_block_root +267 error RN516 out of warranty by 2 months
Owned and running my 516 since 2013. A true work horse.
I went to move the unit, properly shut it down, for some construction being done in my basement.
Plugged it in, turned it on, now...
h0mer
Mar 01, 2019Tutor
So after going through 8 USB drives and a LOT of reboot attempts while plugging in the HDMI to a screen, so I could see when the BIOS triggered boot setup, the reFLASH WORKED!!!!!
So, for anyone who gets this error, definitely be persistent using the recovery utility to make a USB drive that works for re-flash.
- MarcJingerApr 25, 2019Aspirant
Hello Homer,
I got EXACTLY the same issue ! Could you be so kind to indicate me how you prepared your USB boot as I followed very carefully their procedure but it do not work at all.
I used their Recovery tool, I loaded the right (supposed to be) ReadyNASOS-6.10.0-x86_64 ; I plugged a screen + keyboard to make sure the boot priority is on USB : nothing ! I even used the USB autoboot formatter Rufus : nada. Was in your case their official Recovery tool enough to do the job ? Do you think I have to change for other USB keys (I already used 3) ?
Did you just follow their recovery procedure (launching their "usbrecovery" little tool (please see capture) ?
Allways problems with netgear...
Thanks for your help if you can !
Marc
