rcolman
Jan 04, 2018Aspirant
Mounting a drive without a tray help
I cant find a replacement disk tray anywhere in the known universe. It also seems impossible to actually reach Netgear support. So, I tried plugging in a fourth drive using spacers and screws, et...
NXIXN
Jan 05, 2018Apprentice
Hi Rcolman,
I see a post link below, that you can purchase a disk tray:
I would highly recommend not to tweak or jig your unit with alternatives other than a complete compatible disk tray from NETGEAR as it will eventually damage your disk due to disk spin vibrations.
Hope that helps.
rcolman
Jan 05, 2018Aspirant
Thank you for taking the time and trouble to respond. However, I am not concerned about vibration, etc. That is easily solved.
What bothers me is taking a new, unitialized drive (WD 3TB NASware 3.0) - plugging it into the NAS - seeing it on the drive lights during bootup - then it disappears when the firmware loads - not visible in RAIDAR.
This the fourth drive, thank you.
I can't see any electrical or mechanical connections withing the disk tray ... SO why is this happening?
trouble ahead - better off dead
- StephenBJan 05, 2018Guru - Experienced User
Of course there are no electrical connections, but the tray does keep the sata/power connections in the drive well-aligned, with no weight from the drive stressing them.
Likely w/o the tray, your drive power/SATA connections are flakey.
