teknik_kim's avatar
teknik_kim
Mounting ReadyNAS Duo v2 harddrive in Linux (Raspberry Pi)
Hi
I did something incredibly stupid and I'm trying to recover my files. I accidentally started deleting a share on my RND2000v2 but I quickly (within 3-4 seconds) noticed what I was doing and shut down the system using the power button (wasn't sure if cutting the power would be wise).
The drive still shows as almost full (A 2TB Seagate drive) but I cannot access the files from the share.
To save as much data as possible my first notion was to mount the drive on my trusty Rasberry Pi system (with default RasPi Linux dist).
I am, however, not that skilled in Linux command line, and would like some help to proceed further.
Below can be seen the output from a "Sudo fdisk -l" returns and it would seem that /dev/sda3 contains my files (or what's left of them).
Please tell me how I proceed to mount the drive. The drive is apparently RAID formatted, but has never been in a setup with another disk.
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 2048 2335937 2333890 1.1G e W95 FAT16 (LBA)
/dev/mmcblk0p2 2335938 15353855 13017918 6.2G 5 Extended
/dev/mmcblk0p5 2342912 2408445 65534 32M 83 Linux
/dev/mmcblk0p6 2408448 2537471 129024 63M c W95 FAT32 (LBA)
/dev/mmcblk0p7 2539520 15353855 12814336 6.1G 83 Linux
Disk /dev/sda: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xb68ba78e
/dev/sda1 32 4096031 4096000 2G fd Linux raid autodetect
/dev/sda2 4096032 5144607 1048576 512M fd Linux raid autodetect
/dev/sda3 5144608 3907012815 3901868208 1.8T fd Linux raid autodetect
PS: I have looked at other posts but not found what I was looking for.
-Kim
ProSupport for Business
