linkup1
Sep 03, 2017Aspirant
Moving CPU fan connector to IO card from Mobo
I am working on my Biz Pro system that died after a couple quick reboots following a power outage that lasted longer than the UPS did. When researching the issue, I found this article: https://kb.n...
Sandshark
Sep 29, 2017Sensei
What the article fails to point out is that the "some units" it applies to shipped with 3-pin CPU fans. It is intended for those expressly directed to it, not the general public that happens upon it. If your 4-pin fan was running at full speed all the time (which is quite noisy and you likely would have noticed way before you found the article), then you have a different problem. You should not have performed the modification.
