Mij2016
Sep 22, 2016Aspirant
Moving HDD's onto new ReadyNAS 102
Hi there, We have recently had a new Readynas 102 delivered to replace a faulty one which had a broken fan. Can someone confirm if all we need to do is move over the 2 x HDD's to the new device? A...
- Sep 22, 2016
All the configuration details eg IP address, Active Directory details etc are held on the HDD's?
Correct
Mij2016 wrote:
no other action will be necessary?
Personally I would install a scratch disk in the replacement first, and make sure the firmware is matches what is on your disks.
That should not be necessary (if there is mismatch, the newer software win out). But I'd still do it.
Sep 22, 2016Guru - Experienced User
Correct
- Mij2016Sep 30, 2016Aspirant
Hi,
Just to say all was well with swapping over the HDD's.
Thanks for your input.
Grant
