doubleos
Oct 24, 2018Guide
Moving System from Readynas 516 to 716
I'm considering buying a 716 chassis and moving my 516 disks to the new chassis. As I understand it there should not be any problem moving the volumes as long as I move all of the disks for the volumes (correct me if I am wrong), however I want to move my system also. I have applications installed and I added virtualbox which modifies the OS. Can I move the system harddisk to the new system, i.e. will the harddisk and system software be compatible? And if not, what would be the suggested way for me to move?
Thank you to all in advance. I am presently running OS 6.1.
The system is on the disks, so migrating the disks will move both.
If the RN716 is running newer firmware than the RN516, then the new NAS will upgrade the system on the disks. If it is older, then the NAS will update it's flash from the system on the disks. If you want to avoid this step you could install a scratch disk on the RN716 and then manually install the same firmware you are running on the RN516.
- doubleosGuide
Thank you Stephen! So, if I am understanding you correctly. If the firmware on the 716 is newer, I could replace the system hard disk with a scratch one, manually install the earlier firmware and then replace the system hard disk with the one I have on the 516. If the firmware is the same version or earlier, I could just replace the system hard disk and the firmware flash would automatically get upgraded if needed. Is this correct?
- doubleosGuide
Just to make sure. You mentioned that migrating the disks will move the system. Are you saying that the system is copied to the nas volume(s) from the system disk and therefore my modifications to the OS (adding virtual box for instance) and apps would be ported by just moving the volumes?
